Very responsive Steering
Old Mar 24, 2008 | 08:06 PM
Big Blue Ram's Avatar
I have a 03 SLT 4X4 quad cab with 5.9L Diesel. I had the steering box replaced once under warranty in 2006. Since then there is no play in the steering, you move the wheel and the truck is turning. I have never driven an vehicle with steering that tight. Any Suggestions??
I am considering putting another steering dampner on.
Old Mar 24, 2008 | 08:09 PM
06RAM2500's Avatar
Well, it sounds like problem fixed. Does it seem to want to grab, hang up?
Old Mar 24, 2008 | 08:41 PM
Valv's Avatar
I'll trade you with mine plus $ 250.00 !!!
Mine is the opposite, you move the wheel 1/4 of a turn and it still won't make any difference !!!
Actually I will give you $ 300
Old Mar 24, 2008 | 08:54 PM
06er's Avatar
I bought an 01 about a month ago and it has the same problem its almost enough to give arm pump like raceing a dirtbike. Since i have bought it i have replaced the ball joints, trac bar, tie rod, shocks and wheel bearing. It also had a 5 inch lift on it i took that off in hopes that some how that would help it didnt new tires nope allingment no help so let me know if you figure anything out. GOOD LUCK
Old Mar 24, 2008 | 09:06 PM
dj_souvlaki's Avatar
mines at the dealer right now waiting for a new steering box. we will see how it feels when i get it back this week.
Old Mar 27, 2008 | 08:53 AM
Smile
It used to grab and hang up, new steering box fixed that, The truck just has absoultly no play in the steering wheel. All maintance has been done, new tires, balanced, upper/lower ball joints, bearings both sides,new steering dampner, left side front axel u joint, Truck tracks perfectly down road. I have seen other rams with what looks like 2 stering dampners in the front, wondering if that may help, or make it worse. The steering has to be turned back after making a turn also, it does not come back to straight on its own. I have a 2500 chevy with a durmax and the front end is not as heavy as the Ram both are 4x4. This is my first Dodge so far this seems to be my only hic up.
Old Mar 27, 2008 | 10:45 AM
johnh's Avatar
on top of the gear box, there is an adjustment nut. if you have access to a manual, there are full instructions on how to make the necessary adjustments, if you don't, pm me w/ your email address and I'll send pics of the procedure ( if '01 is the same)
Old Mar 27, 2008 | 08:33 PM
CG98x's Avatar
I'm not sure the 03 has that adjustment since it is not the same steering box. If it does it would do the trick. If not be happy there are many dodge truck drivers who would love to have tight steering.
Old Mar 31, 2008 | 07:59 PM
06er's Avatar
becareful with adjusting that nut since i got an allingment 1 1/2 weeks ago ive noticed a small oil leak guess what they over tightened it that was at the dealership today i took it to my regular mechanic and thats what he found. So now i guess i will get to see if the gear box will help my steering i will keep you updated
Old Apr 2, 2008 | 06:49 PM
06er's Avatar
gear box did it drives awsome i cant belive thats all it took to make that big of a differance i was starting to think it wasnt going to fixable but it is. good luck guys
Old Apr 2, 2008 | 06:59 PM
Danderson's Avatar
Another 3rd w/no play.
I spent a fortune trying to correct my '99's steering(Thanks Dodge). My '07 is stricken with the dreaded "No Play" malady. I love it!
blaster668
Feb 26, 2008 12:14 PM
kipper79
Sep 2, 2007 01:48 PM
herb
14
May 15, 2004 07:01 AM
tanderson2002us
Dec 13, 2003 03:46 PM
