Van Aaken / Diagnostic plug
Old Dec 14, 2005 | 06:27 PM
tool's Avatar
Just recieved my Van Aaken box that I bought second hand last night.
I am having a problem installing it. I have the harness plugged into the injection pump loom and MAP sensor, there is however one more plug that I cannot find. Connected to the Van Aaken harness right close to the CPC there are two loight gauge black and ornage wires twisted together which are attached to a small grey rectangular two pin plug with a blanking plug on it...... Where does this one plug into?? I cannot find a similar plug. Can anyone help??
Thanks.
Old Dec 14, 2005 | 06:40 PM
oestreich84's Avatar
That "plug" is if you want to install a on/off switch. The pump connection and the map connection are the only two for the Van Aaken smartbox R. When I installed my switch, I just cut that plug off, extended the wires into the cab, and hooked up a switch. When it snows around here,(we are getting 10-12 inches tonight) I just turn it off. So if you have the pump connected, and the map sensor connected, your done! Have fun
cumminsboy
Jun 15, 2005 06:55 PM
Battering Ram
110
Mar 25, 2004 06:14 PM
Original Junior
Jan 15, 2004 12:26 AM
GLMaines
Oct 7, 2003 09:31 PM
Copenhagenjunkie
May 19, 2003 08:04 AM
