Valve spring pressure???
Old Nov 30, 2007 | 01:42 AM
West Coast's Avatar
I was told a year ago when I had my HG replaced by a shop that they installed heavy duty valves springs in my head ( I was charged for them). I had another HG go last week and I am having the head surfaced right now. The machine shop is going to check the pressure on my springs but needed a pressure number to reference against the springs that are in their now? Anyone know what 60lb springs would be at installed height? And what would stock be?
And where is a good place to get upgraded valve springs if I need them? I ordered a 4K spring kit so I want to make sure I have all the good stuff...
Thanks so much.....
Dave
Old Nov 30, 2007 | 04:02 AM
joker_800watts's Avatar
if you ordered the 4k the same place should carry the 60lbs springs . as for install height it would be the same as stock springs because the valve stem groove where the clips lock would not move. hope this helps
Old Nov 30, 2007 | 10:08 AM
JD730's Avatar
Thanks so much.....
Dave
I do not have a manual handy, but the 60lb spring is fatter in the middle than the ends, wear as the stock spring is straight. It is also taller.
Cummins is the best place to get them.
He's asking for the force the spring would apply at the installed height.
Old Nov 30, 2007 | 01:22 PM
West Coast's Avatar
Thanks Mike, that is what I am trying to ask..... I need to see if the springs I have now are the 60 lbs. But the machine shop is not diesel experts and needed some number to reference the current springs. I don't want to purchase new springs if I don't have to.
Thanks...
Dave
Old Nov 30, 2007 | 04:15 PM
Clayten's Avatar
DTR's Toad Wrangler
My 60 pounders have a white stripe painted on them.
Old Dec 1, 2007 | 09:09 AM
JD730's Avatar
According to my manual the stock valve springs should have somewhere between 80.7 and 89.2 lbs of force when compressed to a height of 1.94".
Approximate free length should be 2.262"
Old Dec 1, 2007 | 09:27 AM
West Coast's Avatar
JD thanks that should help out. Now if I do have to get new 60lb valve springs to I need to get all 12 or just 6 exhaust sides? Thanks for all the help people....
Dave
Old Dec 1, 2007 | 11:31 AM
aksparkey01's Avatar
if you want to run the 4k gsk kit it needs to be all twelve. only need six if you are just going to run an exhaust brake.
Old Dec 1, 2007 | 12:02 PM
West Coast's Avatar
Thanks sparkey.....
Old Dec 1, 2007 | 02:33 PM
BC847's Avatar
1st Generation Admin
OEM on the left, 60# on the right.
DNRCustoms
Nov 24, 2008 09:30 PM
lcaad1249
Jul 14, 2008 10:12 PM
WhoCares79
Jun 3, 2008 11:45 AM
flynhigh205
Feb 26, 2008 10:33 AM
fishin fever
Mar 13, 2006 06:46 PM
