vacumm pump test
Old Aug 24, 2006 | 09:13 PM
mwolfe's Avatar
vacumm pump test
I Have A 1994 Ram 2500 4x4 And The Brake Pedal Gets Hard To Push After Two Or Three Pumps , I Put A Vacumm Gauge In The Line From Pump To Booster And It Takes A While To Build Back Up To 28 Inches Of Vacumm After Brake Pedal Pushed, I Can Pinch Off Line To Booster And Gauge Shoots Right Up , I Have Already Replaced The Booster , I Have A Line Straight From Pump To Booster To Elimate Other Things In The System. Thank You For Your Help
Old Aug 24, 2006 | 11:12 PM
infidel's Avatar
It's well known that the vacuum pump can't keep up with the brakes at idle, I think that's a big reason they switched to hydro-boost.
Dodge's solution is to add a vacuum reservoir tank that costs over $100 but which you can make yourself or buy elsewhere for under $20.
Or you can be aware of the pump's limitations and rev the engine up.
mr bill
Dec 14, 2008 12:18 PM
KATOOM
Dec 12, 2003 01:08 AM
