uncommanded shutdown at idle, will start back up
Old Nov 12, 2010 | 01:15 PM
grapes43's Avatar
My 2001 automatic shut down twice on its own. The first was in park, the second was switching from reverse to drive. It started right back up with no hesitation. I plan on checking fuel pressure when I get home. Also, when I remove my foot from the pedal to slow down for a light, the engine will chug a little. Its on its second lift pump. 200000 on the odo. On a side note, My mileage, temp, mpg, display shuts down after a little bit till I flick it with my finger. What do you think?
Old Nov 12, 2010 | 01:37 PM
rebal's Avatar
check all your ground wires are clean and tight
Old Nov 12, 2010 | 05:07 PM
grapes43's Avatar
ok, will check my grounds. I checked my fuel pressure and at idle it was 12 and 3000 the pressure read nine.
Mike Allred
Jan 22, 2014 09:23 PM
caper11
Jan 29, 2009 03:23 PM
MrMoparMan
Feb 12, 2008 01:11 PM
Ramdriver15
Jul 22, 2006 10:52 AM
JoshPeters
Apr 3, 2005 08:13 AM
