Turbo problem?
Old Aug 25, 2005 | 06:55 PM
grossmann's Avatar
Question Turbo problem?
I have an intermittent power problem at low RPM primarily when cold, but at some times after warm up. It seems that the turbo is not working and the truck will not pull past 1100 RPM accompanied by bluish white exhaust smoke. after a couple minutes it will suddenly kick in and run fine. Any suggestions will be much appreciated.
2002 Dodge 3500 24valve 6 spd. manual
Old Aug 25, 2005 | 08:13 PM
MnTom's Avatar
Welcome to the site. The first thing you need to do is find out if there are any codes. On yours I think you can cycle the key three times and leave the key in the on position (without starting it). If there are any codes you should see them in the odometer window. Do you have a fuel pressure gauge on your truck? If so, what pressures does it show? It does not sound like your turbo is not working. If that was it the truck would smoke black real bad. I am thinking maybe the APPS or a VP44 problem myself. Since it is an '02, wouldn't it be covered under warranty?
Tom
Old Aug 25, 2005 | 10:02 PM
phox_mulder's Avatar
Re: Turbo problem?
Textbook sign of a bad VP44.
Sorry.
Hope you are still covered under warranty.
phox
Old Aug 28, 2005 | 11:58 AM
RifRaf's Avatar
Re: Re: Turbo problem?
Sorry.
phox
Sorry I am dumb but what is VP44 Thanks
Old Aug 28, 2005 | 12:39 PM
Sidewinder's Avatar
The VP44 is the fuel injection pump.
Check this page out. https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Aug 28, 2005 | 06:18 PM
DODGE 92's Avatar
wat they said
Ada381
Feb 10, 2008 07:58 AM
Checkmate
Mar 5, 2005 08:36 PM
callum
Nov 21, 2004 07:04 PM
dogman
Dec 27, 2003 07:06 PM
