Turbo install question....
Old Nov 11, 2006 | 03:08 AM
LethalInjection's Avatar
I can not get the back bolt closest to the block out of the turbo/manifold. Any suggestion what to use? Or how to get at it better. I am tempted to pull the maifold but are the gaskets reuseable? Should I try a impact gun with alot of extensions?
Thanks for any advice....
Old Nov 11, 2006 | 03:38 AM
AlpineRAM's Avatar
Should be accessible with a straight ring wrench and a selection of the fines swearwords. I hce bent one of mine about 10 degrees and it works like a charm.
HTH
AlpineRAM
Old Nov 11, 2006 | 06:39 AM
XLR8R's Avatar
Soak the turbo bolts with KROIL or penetrating oil if you can wait... otherwise, try different combinations of wrenches and cussing
Old Nov 11, 2006 | 09:04 AM
I soaked them for three days before this project and still cant break the stupid bolt loose. Back to it again.
Old Nov 11, 2006 | 09:58 AM
dodgezilla04's Avatar
i ground my box end wrench to reduce the outside diameter so it fit better. the several days of kroil, and then i used my propane torch to heat the nut alittle, shot kroil in there when my wrench was applying alittle pressure and off she came.
Old Nov 11, 2006 | 08:46 PM
chop342's Avatar
From: Climax, MI (between battlecreek and kalamazoo)
i would agree with dodgezilla04 grind down the outside of the box end wrench and heat it up and bend it a little so it will fit. then take a small hammer of some kind and wack that wrench and that bolt will come loose.
Chris
Old Nov 12, 2006 | 09:58 AM
Finally got it with a impact gun but it still took forever.
Old Nov 12, 2006 | 03:42 PM
Dodgezilla's Avatar
Those rear bolts are a real pain!!!!!
Old Nov 12, 2006 | 05:39 PM
infidel's Avatar
Don't know what you used but if you used a real penetrating oil such as Kroil you probably wouldn't have had a problem. WD-40 isn't penetrating oil
Old Nov 12, 2006 | 07:14 PM
I was using PB
Old Nov 12, 2006 | 07:38 PM
Timmay2's Avatar
I took mine off w/ manifold and then used a box end wrench with a long pipe.
Old Nov 12, 2006 | 08:34 PM
Rampage1967's Avatar
PB is good, long extension on an impact gun is bad.
pistazie
ABDTR #5
Apr 30, 2009 08:16 AM
Ada381
Feb 10, 2008 07:58 AM
CRXsi
26
May 17, 2006 11:50 AM
Haulin_in_Dixie
Apr 13, 2005 06:33 PM
redram
Dec 10, 2002 09:54 AM
