truck wont start
Old Dec 16, 2006 | 04:37 PM
nofear's Avatar
truck wont start
i put a fuel pressure gauge on my truck and after i installed the banjo bolt and the needle valve the truck wont start. any help is greatly appreciated.
Old Dec 16, 2006 | 04:52 PM
blackdiesel's Avatar
Registered
crack an injector line or two, at the injector. crank it, when it starts to run go tighten them up
Old Dec 16, 2006 | 05:43 PM
nofear's Avatar
blackdiesel, i tried it at the injector and the banjo bolt at the injector pump but it still wouldnt start.
Old Dec 16, 2006 | 06:59 PM
nofear's Avatar
anybody else
Old Dec 16, 2006 | 07:17 PM
Registered
tighten the banjo bolt down. Then crack number #3 and #4 injector like at the head. the bump the starter. you should hear the lift pump kick on. Do this 3-5 times or till you see fuel leaking out from the lines. then tighten the lines down and shell start. if you dont get fuel to the lines, then you have a much larger problem....
Old Dec 17, 2006 | 12:28 PM
nofear's Avatar
thanks blackdiesel i will try it and see what happens and thanks for all of the help.
Old Dec 17, 2006 | 03:00 PM
nofear's Avatar
Smile
got the truck started about 30 min ago and everything is fine, thaks for all of the help.
rustydeeretech
Jun 16, 2010 09:41 AM
Stroked-Z
Oct 4, 2008 11:28 AM
qcstunter
Jan 9, 2007 04:10 PM
doodah
Dec 15, 2002 05:03 AM
Desert Diesel
Dec 5, 2002 08:53 PM
