Truck Will Not Start
Old Oct 20, 2006 | 07:21 PM
gfd121's Avatar
TRUCK WOULD NOT START BACK UP YESTERDAY AFTER RUNNING FOR 2hrs. GOT IT STARTED BY THE OLD SCREWDRIVER ACROSS THE STARTER BOLT. TOOK THE STARTER OFF AND HAD NEW CONTACTS PUT ON. REINSTALLED THE STARTER AND STILL NOTHING. NO CODES PRESENT. CHECKED THE FUSES ALL GOOD.
Old Oct 20, 2006 | 07:23 PM
Ridiculous's Avatar
sure it's the starter?
Old Oct 20, 2006 | 07:26 PM
gfd121's Avatar
No Thats Where I Started.
Old Oct 20, 2006 | 07:30 PM
Ridiculous's Avatar
ok, well i'm gonna help ya all i can, but first i need to know some symptoms. what's the engine doing, or not doing. is it even turning over, is it turning over but no fire, etc.
Old Oct 20, 2006 | 07:34 PM
gfd121's Avatar
Ok Thanks For Your Time. The Starter Does Not Do Anything. No Noise. I Checked The Codes And Nonething. I Had The Contacts On The Starter Replaced Today Thought That Was The Problem.
Old Oct 20, 2006 | 07:40 PM
Ridiculous's Avatar
when you did this did you smell anything burning like burnt wires? also, did you put the contacts in yourself? and if so, did you inspect the starter further? i've seen starters fry a wire inside into two halves and there fore it obviously wouldn't work. i hope someone will help us out here too. i know how frustrating this can be...
Old Oct 20, 2006 | 07:44 PM
gfd121's Avatar
No Smell. I Had The Contacts Put In By A Shop That Rebuilds Starters.
Old Oct 20, 2006 | 07:52 PM
Ridiculous's Avatar
hmmmm, dang, if a shop rebuilt it, then theoretically they should know what that they are doing. so let's say that they do. but you do have power right, no bad fuse/relay. other than that i'm stumped for know, i'll keep thinking though, good luck to ya man.
Old Oct 20, 2006 | 07:57 PM
gfd121's Avatar
I Checked The Fuses And All Good. I Changed The Relays Around Under The Hood And Still Nonething????????????????? Are There Any Other Fuses/relays I Should Check???? Does The Trailer Relay Have Anything To Do With The Starter????
Once Again Thank You For Your Time!!
Old Oct 21, 2006 | 01:24 AM
Ridiculous's Avatar
first off, no problem for my time, i'm always glad to help a fellow CTD'er out. but i don't think there's any other fuses or anything that you can check. i'm sorry, but you've got me stumped on this, try posting this in the 2nd gen forums too and see if you get any hits. but i'll still sleep on it and let you know. like i said, i really do know how frustrating this can be so i wanna help you out but you got me stumped on this one, but i'll let you know, good luck again..
Old Oct 21, 2006 | 01:36 AM
Timmay2's Avatar
Id check the nuetral safety switches next.
Also, do the accessories (such as radio) turn off when you turn the key to crank? Im not sure if they do on your model, i know mine, they shut off while the engine cranks. This may help narrow down if the igntion is even engaging start, or if the computer is sensing the start signal as well.
Old Oct 21, 2006 | 03:11 AM
SMOKNISB's Avatar
Have you checked for power on the starter yet? You should have a constant 12volt on the large red cable, then when you turn the key over, you should have 12volt on the small wire on the solenoid. You need to make sure you are getting power to the starter, then go from there.
Old Oct 21, 2006 | 04:16 AM
Marine's Avatar
Veteran: Marine Corp
You say you got it started by jumping the starter with a crew driver. When you took the starter to the shop, did they test it first, and what did they come up with?
If you jumped it with the screwdriver, that means there is power at the starter. When you put the starter back on, did you wire it backwards?
You need to ensure power on the hot line.
Old Oct 21, 2006 | 08:24 AM
gfd121's Avatar
there is power to the starter on the big red wire but no power on the smal wire.
Old Oct 21, 2006 | 08:33 AM
Marine's Avatar
What did the shop say was wrong? I can't believe they didn't test it. I would take it back.
