Truck lost power...Injector???
Old Jun 28, 2007 | 08:32 PM
Checkmate's Avatar
Was going up the on ramp today and all of a sudden the power dropped to about 1/2. For someone not knowing the power under the hood, the truck would SEEM to be perfectly normal.
I have lost much hp and it won't blow black smoke anymore. I am now leaking fuel under the hood and it appears to be somewhere along the top portion of the drivers side engine (yes near the fuel rail) can't quite see the exact leak, but it's bad enough I could smell it while driving 70 mph.
I am thinking bad injector, but would this cause a leak?
Any and all help greatly appreciated, thanks, Dan
Old Jun 28, 2007 | 08:47 PM
Rpainter's Avatar
CHECK OIL your crankcase vent is on driverside of motor if the motor and everything under the truck is wet you may have more fuel in the motor than in the tank check oil level before driving truck again
Old Jun 28, 2007 | 09:42 PM
DADDY'S DIESEL's Avatar
This sounds familiar to me.
Old Jun 28, 2007 | 09:43 PM
Checkmate's Avatar
I checked the oil just after it happened, and then again when I got home from work (75 miles later) and the oil level was the same. I'm gonna drive the car tomorrow just to be safe though.
Old Jun 28, 2007 | 09:54 PM
dodgezilla04's Avatar
if the crankcase was overfull, it wouldnt be at the top of the motor. you may have a loose fuel pipe, or a broken 1.
be careful looking for it if the truck is running, 20,000psi can severly hurt you.
Old Jun 28, 2007 | 09:59 PM
Checkmate's Avatar
Would a bad or craked injector leak outside the motor instead of into the motor ?? If not, then I guess I probably do have just a fuel line leak and if so that may be causing less fuel pressure to the rail meaning the reverse of a pressure box effect...???... Am I correct on this thought? The only thing I would not understand with this theory is WHY would the engine tick be louder ?? Would less fuel rail pressure cause the injectors to get louder ??
Old Jun 28, 2007 | 10:08 PM
Maybe it not the same as what I had.
https://www.dieseltruckresource.com/...d.php?t=155579
Old Jun 28, 2007 | 10:20 PM
checkmate, i am assuming this is about your '03. the injectors are under the valve cover. the fuel pipes go into cast in fuel galleries in the head and the injectors seat against the galleries in the head. there is no way for an injector to leak externally(unless the valve cover is off ). you will find a bad pipe, or leaking relief valve at the rail.
Old Jun 29, 2007 | 04:53 AM
Checkmate's Avatar
dam. I was sort of hoping for a reason to upgrade.
Old Jun 29, 2007 | 10:39 AM
you can always upgrade just so you dont have to worry about the stock ones going. i am.
Old Jul 4, 2007 | 10:33 PM
canuck101's Avatar
There's a return line going from the injector pump back to the tank. It's rubber for about 18 inches at the back of th engine on the drivers side.I changed one. Be prepared to sacrifice some skin if thats where it's leaking. It's a S.O.B. to repair.
Good Luck.
S.Dodge
Jul 29, 2009 07:45 AM
OWN BAJA
Apr 23, 2006 06:42 AM
big pappa
Sep 23, 2004 07:35 PM
popeye
Feb 4, 2004 08:57 AM
