Trouble codes
Old Jan 30, 2003 | 01:28 PM
RacingD98's Avatar
Re:Trouble codes
It has been on only once and that was Monday going to work, that evening leaving work it was no longer on and has not been on since. But still down on power.
Old Jan 30, 2003 | 01:31 PM
drecu's Avatar
Re:Trouble codes
[quote author=RacingD98 link=board=13;threadid=10182;start=15#98422 date=1043954907]<br>It has been on only once and that was Monday going to work, that evening leaving work it was no longer on and has not been on since. But still down on power.<br>[/quote]<br><br>I would clean the MAP sensor &amp; how's you lift pump? also clean the IAT.<br><br>DRecu!
Old Jan 30, 2003 | 03:21 PM
RacingD98's Avatar
Re:Trouble codes
Calling for a high in lower 60's on Sunday and I may be off from work, will try to work on cleaning MAP &amp; IAT sensors then. Don't have a fuel pressure gauge, but I am assuming it to be OK. Don't know for sure.
Old Jan 30, 2003 | 04:16 PM
BigBlue's Avatar
Re:Trouble codes
Last time I assumed that with my LP, I had 8 psi at idle and 0 at WOT. My check engine is not on. It has been on once or twice in the past couple of weeks but that was because I unplugged the comp with the truck running. I cleaned my IAT about a month ago. Never cleaned my MAP sensor. How do you do that? Shoot some carb cleaner in it to?
ridlangus123
Dec 30, 2013 08:36 PM
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
gofastman
Jan 6, 2003 04:17 PM
