Trouble codes
Old Jan 28, 2003 | 08:27 AM
ram4fun's Avatar
Trouble codes
I get these for trouble codes where should i start .<br><br>Trouble Code: P1693 <br>Description: A companion DTC was set in both the ECM and PCM<br> <br>Trouble Code: P0500 <br>Description: Vehicle Speed Sensor ???<br><br>
Old Jan 28, 2003 | 08:27 PM
Stamey's Avatar
Re:Trouble codes
I dunno what you got, but get in touch with ScubaSteve. He's got exactly the same codes. I don't know if he fixed his yet though.<br>See this thread:<br>http://www.dodge-diesel.org/yabbse/i...;threadid=9827<br><br>Chris
Old Jan 29, 2003 | 11:09 AM
BigBlue's Avatar
Re:Trouble codes
How do you pull up the codes? My buddy's ford all you have to do is turn the key on and off 7 times.
Old Jan 29, 2003 | 11:17 AM
drecu's Avatar
Re:Trouble codes
[quote author=BigBlue link=board=13;threadid=10182;start=0#97882 date=1043860199]<br>How do you pull up the codes? My buddy's ford all you have to do is turn the key on and off 7 times.<br>[/quote]<br><br>Hold on the trip reset button &amp; turn the key th the on position do nopt start &amp; wait it will do a system check in the trip computer window!<br><br>DRecu!<br><br>BTW it's pretty neat!
Old Jan 29, 2003 | 11:29 AM
RacingD98's Avatar
Re:Trouble codes
Turn the ignition to the on position 3 times leaving in the on position on the third try.<br><br>I also am getting codes P-1693 and P-0237. Code P-0237 I believe is low voltage to the MAP sensor. I think I can diconnect the battery for about 30 minutes and the codes will be erased, is this true and/or is there a slicker way to erase the codes? I want to erase mine to give the MAP sensor a chance to throw the code again. I have read that you could get this code from an over boost situation.and when this happens the engine goes into a derated power mode which would explain why I have no power until I get to about 2000 RPM.
Old Jan 29, 2003 | 11:32 AM
RacingD98's Avatar
Re:Trouble codes
drecu, I was typing when you posted. 3 times on the iginition worked on my 2001 but I will try your method also.
Old Jan 29, 2003 | 05:17 PM
BigBlue's Avatar
Re:Trouble codes
Alright. I'm going to try both ways here in just a bit. I'll let yall know which one worked for me.
Old Jan 29, 2003 | 05:38 PM
BigBlue's Avatar
Re:Trouble codes
Alright. Went and scanned the truck. Turned the key on and off three times. Here's what I got:
P PCU ------ P 1693
P ECU ------ P 0237
What do these codes mean?
I don't know if you can erase the codes. I had my batteries unplugged for an hour with the key in the run position doing the APPS reset and the code is there today. Don't know if it was there before or not. This was after I unplugged the Comp.
Old Jan 29, 2003 | 08:10 PM
danlit's Avatar
Re:Trouble codes
0237 turbo circut A sensor low. 1693 will always be there if you have a box.<br> Danny
Old Jan 30, 2003 | 12:38 AM
tmiller24's Avatar
Re:Trouble codes
You have to have a code scanner or a computer diagnostic link, to reset the codes on an OBD 2 vehicle. Even then you still won't completely remove them from memory,that's what my friend the mechanic tells me.
Old Jan 30, 2003 | 05:31 AM
RacingD98's Avatar
Re:Trouble codes
Disconnected the batteries for little over 30 minutes last night, looks like it did not erase the codes. Plan &quot;B&quot; is to let my son take it to his auto shop class and clear codes with OBD II scanner, which won't happen now till next week with the white stuff falling.<br><br>BigBlue,<br>Is your truck way down on power between 1200 and 1800 RPM? You are getting the same codes I am and my power is down right embarrassing.<br>
Old Jan 30, 2003 | 08:54 AM
BigBlue's Avatar
Re:Trouble codes
I dont' know if it is the TC acting up more than ever, or what, but the power does seem a little low. I've got to rev it pretty high to get it to go somewhere. Maybe I'm just used to having the Comp on 1x3 the whole time. I'm thinking that it may be the TC slipping. Can't really tell. I'll let you know later.
Old Jan 30, 2003 | 09:32 AM
KatDiesel's Avatar
Re:Trouble codes
[quote author=danlit link=board=13;threadid=10182;start=0#98104 date=1043892638]<br>1693 will always be there if you have a box.[/quote]<br><br>This is not a true statement. I only had a 1693 when I caused it on purpose. Once I cleared it it was gone. I've got a COMP box.
Old Jan 30, 2003 | 01:17 PM
drecu's Avatar
Re:Trouble codes
[quote author=RacingD98 link=board=13;threadid=10182;start=0#98240 date=1043926260]<br>Disconnected the batteries for little over 30 minutes last night, looks like it did not erase the codes. Plan &quot;B&quot; is to let my son take it to his auto shop class and clear codes with OBD II scanner, which won't happen now till next week with the white stuff falling.<br><br>BigBlue,<br>Is your truck way down on power between 1200 and 1800 RPM? You are getting the same codes I am and my power is down right embarrassing.<br><br>[/quote]<br><br>Is your check engine loight on? <br><br>DRecu
