Transmission problem I need HELP
Old Jun 12, 2009 | 10:44 AM
Black and Silve's Avatar
Trans will not shift out of first gear at all. I can pull the relay and put it into limp "third" it will then shift manually into second and that is it. When you turn the truck off and start it back it is stuck in first again. I reset the apps and it shifted fine, but the brake and abs light came on. I shut the truck off and turned it back on the brake and abs light did not come on but it was stuck in good ole first gear again.
Old Jun 12, 2009 | 11:40 AM
cincydiesel's Avatar
First off welcome to DTR.. Second, what kind of truck do you have? What year, auto or stick? If auto it could be the 1-2 shift band
Old Jun 12, 2009 | 05:17 PM
Sorry it is a 99 2500 4x4 with an automatic. I am not sure about the shift band because when I reset the apps it shifted fine till I shut it off. If the band were bad wouldn't I be able to start out in second and go from there, or shift it manually.
Old Jun 12, 2009 | 05:20 PM
mikmaze's Avatar
electronics could be a bad ground, check the ends at the batteries, clean them and if not, at least ya got clean grounds.
Old Jun 12, 2009 | 05:47 PM
I cleaned all of the grounds batteries, frame, body, engine. All I got was clean grounds guess it doesn't hurt.
Old Jun 12, 2009 | 11:12 PM
oldblues's Avatar
hi
red the codes and post them here !
Old Jun 13, 2009 | 02:47 PM
cpthook's Avatar
06 2500 shift problems
my 06 dodge with auto tranny hesitates to shift into third gear and sometimes bumps back and forth between 2nd and third. the local dodge dealer has been throwing parts at it for 2 weeks and I am out about $2500.00 with still no solution. any good guess?
Old Jun 13, 2009 | 04:50 PM
J BODY's Avatar
you really need to start your own post.
blk&slvr.....scan tool is needed.
Old Jun 13, 2009 | 05:19 PM
Dinner's Avatar
First things I would check is fluid level. After that I would check your kickdown cable adjustment. Being as it is connected to the APPS, it may need adjusting for some reason.
Other options you could try is test your speed sensor on the tail end of the transmission. Or your governor solenoid is faulty inside the valve body.
If you have access to a scan tool that can monitor transmission, hook it up and see what it's doing at a sit still and while driving.
Old Jun 13, 2009 | 05:31 PM
JFlory's Avatar
Definantly sounds like an electrical issure. I would start with the sensors in the tranny. Governor sensor, transducer, and speed sensor. Gonna run around $300 for all three from the dealership and yes, that is only place to get them. And no, you cannot return them if it doesn't solve the problem. They are yours when you walk out of the building.
If that doesn't fix the problem, then your most likly looking at an entire rebuild anyhow, so the new electronics will carry over.
As others have stated, get a scanner on it asap, and post what is going on.
Old Jun 14, 2009 | 07:53 AM
It threw a speed sensor code. So it replaced the output shaft speed sensor and it is all fixed it actually shifts better than it ever has or at least it shifts when it is supposed to. Thanks for the help and the responses.
blkdieselpwer
TXDTR #8
Aug 24, 2009 09:06 AM
bigfish5
Sep 12, 2008 11:14 PM
rmillett
Dec 18, 2006 03:39 PM
dogman
Dec 27, 2003 07:06 PM
