Transfer Case Problem
Old Apr 8, 2003 | 09:46 PM
2ndF's Avatar
Hello everyone, <br><br>First time here<br><br>I have a 92 D250. The problem I have is kind of strange. When I am in 2WD I get a panging/grinding noise from the transmission or transfer case. It almost like a bearing is loose inside.<br><br>Leaving the truck in 2WD with the hubs locked the noise goes away. When I crank the wheel to turn I get a similar noise but without the violent panging. <br><br>Please let me know your thoughts on this. <br><br>I have sourced a remanufactured transfer case in Las Vegas NV but before I commit I am still in troubleshooting mode.<br><br>Thanks<br><br>Sean<br>
Old Apr 9, 2003 | 10:49 AM
bulthisl's Avatar
Re:Transfer Case Problem
Check the adjustment of your T-case shifter.<br>I had the same prob one time on a GMC.<br>The shifter is not disenguaging the T-case with enough clearence and the gears may be tipping causing this.<br>With the hubs locked ALL gears are turning and the TIPPING goes away.<br>Just something to check.<br>It happened to mine and I put a new shifter assembly on T-case and all was good. The old was worn plum out.<br><br> : Eddie : 8)
wyododge
Aug 18, 2011 07:48 AM
Armapoc
Jan 8, 2006 02:10 PM
alltimelow1
Mar 30, 2005 08:18 PM
Ram350
Feb 3, 2005 04:40 PM
