Trans fluid atf+3 atf+4???
Old Aug 15, 2006 | 02:57 PM
Mslaughter's Avatar
I dropped my pan and I'm getting ready to buy new fluid, does my 47rh use atf+3 or atf+4? Also I think +4 is synthetic would that mix ok with whats left in the vb and torque converter?
Old Aug 15, 2006 | 03:42 PM
HOHN's Avatar
The RHs used +3, IIRC.
I'd use +4 in it, and it will mix just fine with the older stuff.
You might want to call a performance tranny shop, as the +4 is slippery stuff, and the trans might slip if it's near the end.....
Old Aug 15, 2006 | 06:00 PM
phox_mulder's Avatar
+4 is a bit more $$ than +3,
I'd stay away from the former and use the latter, besides, it's what Dodge says should go in there.
phox
Old Aug 15, 2006 | 06:05 PM
mr T's Avatar
i use dexron/mercon 3...use a friction modifier like lube guard if u dont like the firm shifting...but i think atf 4 is unnecessary
Old Aug 15, 2006 | 07:25 PM
Mslaughter's Avatar
A buddy of mine told me to use that, but I've never heard of anyone using it before in a chrysler. I looked and it said its only recommended for some ford, gm and imports so I went ahead with the +4 just to be on the safe side. Hows would the dexron 3 have mixed with the current leftover fluid? Also how well does it protect the RH? Just wondering because I might try using it next time to get a firmer shift.
Old Aug 15, 2006 | 07:36 PM
mr T's Avatar
well the boys at DTT like DM 3...infidel over here like DM 3...there's plenty of guys who like it...i got DM 3 and i added one bottle of lucas seal conditioner etc...cause its still my original tranny
Old Aug 16, 2006 | 09:52 AM
infidel's Avatar
Big advantage to Dexron is that Costco sells it for 69¢ a quart.
Works excellent and is recommended by most of the big name diesel tranny rebuilders.
Old Aug 24, 2006 | 06:44 PM
mikmaze's Avatar
just a notwe here, the local wally world has mopar atf 4 on the shelves, 4.62 a quart.......... finally a place to find this mystery fluid.
Pig
23
Jun 4, 2010 01:01 PM
Tommy93w350
Jun 26, 2007 04:42 PM
2500
Oct 2, 2006 09:14 PM
dieselfan
Aug 5, 2006 10:44 PM
Pig
Mar 13, 2006 09:12 PM
