Trans fluid atf+3 atf+4???
I dropped my pan and I'm getting ready to buy new fluid, does my 47rh use atf+3 or atf+4? Also I think +4 is synthetic would that mix ok with whats left in the vb and torque converter?
The RHs used +3, IIRC.
I'd use +4 in it, and it will mix just fine with the older stuff. You might want to call a performance tranny shop, as the +4 is slippery stuff, and the trans might slip if it's near the end..... |
+4 is a bit more $$ than +3,
I'd stay away from the former and use the latter, besides, it's what Dodge says should go in there. phox |
i use dexron/mercon 3...use a friction modifier like lube guard if u dont like the firm shifting...but i think atf 4 is unnecessary
well the boys at DTT like DM 3...infidel over here like DM 3...there's plenty of guys who like it...i got DM 3 and i added one bottle of lucas seal conditioner etc...cause its still my original tranny
Big advantage to Dexron is that Costco sells it for 69¢ a quart.
Works excellent and is recommended by most of the big name diesel tranny rebuilders. |
just a notwe here, the local wally world has mopar atf 4 on the shelves, 4.62 a quart.......... finally a place to find this mystery fluid.
