Trans Fluid
Old Feb 1, 2009 | 02:18 AM
jaswright2003's Avatar
Trans Fluid
I just found out that when my tranny was installed there was dextron III/mercron put in it, but it already had ATF+4 in the torque converter, and one of the fittings on the heat exchanger is slowly leaking so I have been adding Mopar brand ATF +4 to it.
Do I need to flush it immediately?
If so will it be alright to drain the pan, change the filter, fill back with ATF +4, disconnect the return line, and start and fill.
Old Feb 1, 2009 | 10:00 AM
infidel's Avatar
I wouldn't worry about it one bit but from now on use Dexron,
way cheaper and works just as well.
Old Feb 1, 2009 | 10:25 AM
dozer12216's Avatar
They are not compitable. They have different charactistics.
archer39
Dec 5, 2009 07:40 PM
mar67655
Mar 14, 2009 07:22 PM
nfsommer
Nov 9, 2007 09:36 AM
2500
Oct 2, 2006 09:14 PM
icrider
Sep 27, 2006 03:10 PM
