Tranny jumps out of overdrive
Old Jan 8, 2004 | 12:39 AM
farrdog's Avatar
Thumbs down Tranny jumps out of overdrive
I have a 95 diesel that every so often pops out of OD while driving normal Highway speeds. I push the OD button and it returns to normal operation and wont do it for couple months .
Will a bummpy road cause this or what . The truck has 115k and change the filter and fluid every 12K . And how do I get rid of that stupid transfercase shifter rattle ?
Old Jan 8, 2004 | 12:57 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Sounds like the TPS is bad or needs to be cleaned real bad. I replaced mine and it quit that nonsense
Old Jan 8, 2004 | 12:59 AM
farrdog's Avatar
Whats the tps?
Old Jan 8, 2004 | 01:04 AM
farrdog's Avatar
Throttle postion sensor?
Old Jan 8, 2004 | 09:50 AM
RATTLINRAM's Avatar
Throttle Position Sensor
Can sometimes be the culprit for transmission shifting problems. When one of these goes bad, the auto tranny might hunt, or go in and out of lockup at speed.
Check Here
Old Jan 10, 2004 | 09:28 PM
rhills's Avatar
yup mine did the same thing 250.00 at dodge you can put it in your self its really easy.
Old Jan 13, 2004 | 05:50 PM
farrdog's Avatar
Cool, I'll go down to the parts store and see if I can't get one. I've also been noticing that the truck has been taking a long time to shut down after I pull the keys out of the ignition . It didnt do that till i had the torque plate changed on the injector pump. the truck is sometimes wont start up , so then i give a little throttle and it fires right up . Whats up with this ?
Thanks for the info
FARRDOG
Old Jan 13, 2004 | 06:31 PM
kandgo's Avatar
Try cleaning your tps first before buying, they are also known to cause trouble with bleed over in the wire loom and some have had great luck taking the wires out of the loom and seperating them. 99% of the time it is either dirty or the wire problem. There is a fellow here by the name of olivmat that sells the rewire kit, I would exhaust those two avenues first before spending $250 or more, Goodluck, Rick
Old Jan 13, 2004 | 08:50 PM
infidel's Avatar
Rick is right, save your money. Even replacing the expendsive tps doesn't guarantee your problem will be solved. The tps usually only needs to be cleaned or adjusted. I'm running my stock tps after 200k. It acted up for awhile around 20k till I figured out that spraying the shaft into it with electronic cleaner while working the throttle back and forth at every oil change took care of the problem. You can also check the voltage as per these instructions- http://dodgeram.org/tech/transmissio...TPS_adjust.htm
If that doesn't fix it remove the wires that run to the tps from their loom and separate them all the way to the pcm.
If that still doesn't do it replace the wires with shielded ones.
The tps works off very low voltage, just a little interference can throw everything off.
Old Feb 4, 2004 | 11:59 PM
farrdog's Avatar
I cleaned it and went on a 1k trip with no issues with it . the torque converter is hateing me now under accleration from a stop . The converter wont lockup till high gear then it sets you back in your seat , its starting to shudder a little to .
Any good suggestions on this problem ? I fear i need spend more money than I want to on a new converter .
Thanks
95 2500 4x4 115KmilesCranked up injector pump and strait piped
Old Feb 5, 2004 | 05:37 AM
infidel's Avatar
Go light on the accelerator and keep od off until over 50 mph or be prepared for a trans upgrade.
Busboy
Jan 23, 2015 01:12 AM
zmann
Jun 12, 2010 10:24 AM
98xc800
Feb 1, 2008 08:04 PM
colesdad
Jan 5, 2007 06:06 PM
hvanflee
Jul 12, 2005 08:14 AM
