Trailer lights not working (issue is w/truck)
Old May 11, 2009 | 03:18 PM
bluesurf's Avatar
My left trailer directional and stop lights are not working on the truck side. I checked the connection and the fuse but all looks good. Brake light works. How can i fix this quickly without going to dealer. Can it be in computer? I figured the fuse would be blown if there were an issue. Thanks for any ideas.
Old May 11, 2009 | 10:03 PM
cameroneod's Avatar
Did you check for corrosion in the plug? Might be worth a shot to pick up some dielectric grease.
Old May 11, 2009 | 10:54 PM
roughstock's Avatar
I think this is a common problem. I think. Do some searchingon here.
Old May 12, 2009 | 07:24 AM
Jeff in TD's Avatar
There was a TSB for a reflash of the integrated power distrubution module, but I think that was only for 06's.
Old May 12, 2009 | 09:12 PM
rich's Avatar
check the splices where your plug is wired to
Old May 14, 2009 | 09:39 PM
hot shot's Avatar
have the same problem.had it checked out and they said the wire was bad to the fuse box.had to run a jumper wire for the blinker on the truck and then jumped the wire for the breaks across the back of the trailer.temp fix but it works for now.
Old May 15, 2009 | 01:53 AM
BearKiller's Avatar
Situations like this is why I never wire a trailer into any factory-supplied trailer harness.
I always wire my trailer-plugs direct to the source and my marker-lights are always on a switch of their own, completely independent of the factory headlight switch.
I am forever having to bypass the factory mess on various makes and models.(other peoples trucks. I don't own anything new enough to have that stuff)
Sleigher
May 4, 2017 02:12 PM
monsteredge
Nov 24, 2009 01:44 PM
Marcus
Sep 1, 2008 03:54 PM
Bobs dodge
17
May 19, 2008 10:50 PM
pullin hard
Mar 18, 2007 06:46 PM
