Terrible squeak in steering column!
Old Apr 11, 2004 | 05:08 PM
Marine's Avatar
Veteran: Marine Corp
Question Terrible squeak in steering column!
How do I get rid of it? It happens within 180 degrees of straight ahead. I have tried silicone spray all over the steering column and still squeaks.
Any ideas?
Thanks, Mike
Old Apr 11, 2004 | 06:53 PM
infidel's Avatar
Probably the clockspring getting ready to fail.
You're probably still under warranty, let the dealer deal with it.
Old Apr 11, 2004 | 07:13 PM
Marine's Avatar
I figured that as well. I already had it replaced at 35,000. I am now at 78,000.
Mike
Old Apr 13, 2004 | 09:35 PM
Marine's Avatar
Found it...it was the transmission linkage.
Mike
Old Jul 14, 2004 | 06:00 AM
ReedRosa's Avatar
Marine, Just read this post. I have this problem as well. Did you grease the transmission linkage? What part of the transmission should I be looking at and what kind of grease did you use. Thanks. Mine just started at 64000 miles.
Old Jul 14, 2004 | 12:54 PM
MLR1's Avatar
Look for the shift rod that runs from the body to the transmission. This rod will connect to the steering column @ the body side & the valve body on the trans side. Lube both pivot joints (1 on each end) and the problem will most likely go away.
Old Nov 4, 2005 | 10:02 PM
Marine's Avatar
It is back! I am going to try the lube on the shaft that MLR1 mentioned, then I will try the fuel line fix for it from J Body.
littlebuddie
Jun 10, 2011 11:57 PM
shep1
Aug 29, 2010 10:19 PM
CTD2001
15
Nov 28, 2009 07:54 PM
ytodd
Nov 2, 2007 09:57 AM
gman07
May 9, 2007 06:03 AM
