Stumble and Dies
Old Dec 11, 2006 | 04:00 PM
Askgeneral's Avatar
Stumble and Dies
I'm workin on dad's 02 2500, It's got rough idle and will cuttoff like you killed it with the ignition. Pulled codes and had glowplug/heater and CPS. Changed CPS and still doing same, minus the code. Sometimes it will run an hour, some times 30 sec. We changed lp and ip bout 4 months ago, installed fuel pres. meter, got a consistant 7-10 psi at idle, even when engine dies.
Any and all advice appreciated
Old Dec 11, 2006 | 07:08 PM
XLR8R's Avatar
Well, we know there can't be anything wrong with the glowplugs...
Old Dec 11, 2006 | 08:32 PM
Askgeneral's Avatar
No words of wisdom from the guru's tonight?
Old Dec 11, 2006 | 09:08 PM
XLR8R's Avatar
Could you fill out your sig, please?
Old Dec 11, 2006 | 10:23 PM
Clunk's Avatar
Turn the keyswitch on-off-on-off-on then look at the odometer.
Exactly which code numbers are you showing?
Is the motor stock with no modifications?
Old Dec 11, 2006 | 10:28 PM
RCW's Avatar
RCW
Assuming you have changed the fuel filter and your flexible fuel hoses are less than three years old, on an 02 2500 I would suspect the fuel injection pump has failed if your transfer pump is maintaining the pressure you list. Lack of relevant codes are what lead me down the VP44 failure path. Just about anything else will create error codes except dirty/plugged fuel filter or fuel hoses that infiltrate air (by the way the hoses will be dry, as they develop porosity and leak air not fuel).
It the problem just began with a change in weather, then look at the IAT and MAP for potential failures. Either of those generally will generate an error code, but sometimes not.
Old Dec 12, 2006 | 10:11 AM
Askgeneral's Avatar
If it were bad fuel lines, wouldnt I see that on my fuel press. meter?
I assumed if it were a leak or something like that before the IP I'd see it on the meter.
vintovka
Apr 30, 2012 12:38 PM
90 power ram
Oct 6, 2011 08:04 PM
Mcmopar
Jul 18, 2006 12:29 PM
03CumminZ4X4
Jan 23, 2006 01:49 PM
draebi
Feb 27, 2004 03:23 PM
