Steering Nuckle 4x4
Old Dec 1, 2004 | 07:08 PM
Joseph H. Smith's Avatar
Steering Nuckle 4x4
How do you get the steering nuckle off an fbi 248 1998 4wd. The manual says to beat it with a brass hammer and I have been beating it and it will not come loose. The truck needs to be done tonight but I am concerned about damaging the nuckle at the ball joint seats. I am replacing the ball joints and I have all of the tools I need but separating the nuckle from the ball joints which have to be done at the same time is proving not to be a simple as hitting it a couple of times with a brass hammer like the manual says.
Old Dec 1, 2004 | 10:07 PM
Hemi Cat's Avatar
Beat it off??? with a brass hammer??? I generally use a pickel fork. There are different sizes so pick the correct size for your joint. To replace the joints I use a ball joint press. It's like a big C-clamp with adapters to fit the joint to press it out then in without stressing the knuckle.
Old Dec 3, 2004 | 05:30 AM
I was able to get it off by just beating it with a hammer. Not the ball joint itself but the seat where the ball joint neck slides into. After getting the nuckle off I found a lot of corrosion in the seat for the upper ball joint. So it was the upper that was keeping it from coming off. I cleaned it up, pressed out the upper ball joint, applied anti seize lubricant to all surfaces, pressed in the new joint and assembled everything. By the way you can't fit a piece of paper between the u-joint and the 90 degree gease fitting that came with the joint. I prefer non-greaseable joints.
Old Dec 3, 2004 | 08:43 PM
Hemi Cat's Avatar
I know what you mean. You need an adapter for your grease gun that has a needle point on it to poke it in the check ball hole of the fitting so you can pump grease in it. I think Lincoln has a good assortment of adapters. Check with your local auto parts store.
V.R.Wheeler
Aug 4, 2007 01:00 PM
catnfool
Dec 31, 2006 11:35 PM
2500
19
Sep 27, 2006 11:50 AM
1320
Jul 25, 2006 10:57 PM
Ridgetop
Jan 26, 2006 02:18 PM
