Starting problems, Revs on start up
Old Jun 15, 2007 | 04:49 PM
jta's Avatar
jta
My truck does this on a rare occasion. it did it before the juice w/ attitude. I did a search but didn't find anything. If you shut it off, turn the key to the off position give it a few sec it will fire up right with no problems. It doesn't have any lights on on the dash. Any body got any I ideas? My specs are in my sig.
Old Jun 15, 2007 | 05:03 PM
H2SRDMB's Avatar
how bad does it rev... just a little higher than normal.. or does it take it to like 2000 rpm.. 3000.. ? does it hold there for seconds. or is the initial start high then slows down to nowrmal after a second or so...
my guess would be too much fuel at start. or a tps problem.. i know at the age of our truck the tps`s seem to go out,i did mine 6 months ago!
nexplian a little more in detail. try to think of everything . maybe it will be someting simple..
Old Jun 15, 2007 | 05:10 PM
jta's Avatar
jta
It revs like you are mashing the gas pedal to the floor. I don't let it go long enough to see if it will come down.
Old Jun 15, 2007 | 05:50 PM
H2SRDMB's Avatar
have you tried an APPS reset. if not do a search for it. it might be one of the causes. i have seen tps`s do crazy things like going wide open for no reason!
heres a link
https://www.dieseltruckresource.com/...n&onlynewfaq=1
hopefully this works.. if not keep us posted. and hopfully we can get this solved
Old Jun 19, 2007 | 04:45 PM
jta's Avatar
jta
I have not had a chance to work on it but here is some more info. When this happens it resets my Juice, I have to go back through the set up on it. Also if I try and start it w/o the 4-5 sec delay after it happens the "wait to start" light comes on but the fuel pump does not run, not even if I bump the starter to make it run like when you bleed the system. Anybody else have a problem like this?
Old Jun 19, 2007 | 10:28 PM
XLR8R's Avatar
.... and you're positive this phenomenon occured before the Edge Juice was installed?
Old Jun 20, 2007 | 02:28 PM
jta's Avatar
jta
I'm 100% sure
dkenny
Dec 7, 2013 07:08 PM
spitzair
Jul 20, 2010 08:43 PM
estrada5.9
Nov 5, 2007 12:15 AM
pwknapp
Oct 22, 2003 09:06 PM
dt4792
Apr 20, 2003 06:48 PM
