starter trouble
Old May 18, 2006 | 07:23 PM
chadwick's Avatar
starter trouble
alight guys i just got into town from a work trip and i went to start my truck and it just clicked so i just thought i left a light on let it charge a little while. went back out it just clicked so i tried a few times and it started. So i drove it in front of the shop to wash it and now it wont start again. i have tried the old metel pipe agaist the start but its not working what do i do. By the way i am stuck at work
Old May 18, 2006 | 07:41 PM
chadwick's Avatar
alights guys i got it started but something is wierd. i went back out after doing the search option on other peoples starter problems. I tried three times to start it and it just clicked on the fourth tie it turned over a couple times then clicked. I tried again and it fired up like normal. i probley tried 5 times of shutting it off after it started of killing it and firing it back up and it worked like normal. does that sound like it could be the starter contacts. i checked the codes,they showed nothing
Old May 18, 2006 | 10:21 PM
bentwings's Avatar
How many Miles on your truck. Sounds like the contacts are bad. About an hour job with the right tools. Nothing like being stranded in the middle of nowhere with a bad starter. You could probably get a rebuilt for $200 and just do it. $35 or less for contacts.
Mine jambed the starter and it ran untill it burned up. I never heard it run or saw any thing on voltmeter. Killed new batteries too.
Old May 18, 2006 | 10:25 PM
ds1rider's Avatar
Usually with the contacts it shorts our the fuse.
Old May 18, 2006 | 10:32 PM
chadwick's Avatar
there are about 157000 on the truck and i dont know if anybody ever had to replace them or the starter. I am going to replace them anyway
Old May 18, 2006 | 10:57 PM
torquefan's Avatar
Good idea. I'm 95% sure that's your problem, but if not, it's just one less thing to go wrong later.
FMB
Nov 14, 2010 09:09 PM
12valvesmoke
Jun 12, 2009 09:46 AM
buckman361
Nov 13, 2008 09:54 AM
Paradise Racing
Jan 18, 2005 09:08 AM
ts
Dec 10, 2002 11:35 PM
