Starter?
Starter?
So, I'm three hours from home and I just tried to start my truck. It started to crank but stopped before it even turned over enough to start. I turned the key off and waited then tried again and now it won't crank at all. Is there a fuse or something for the starter? I can hear the grid heater and the fuel pump, just no power to the starter.
Try starting it in neutral. If not....try unhooking the battery to reset the TIPM. There is a flash for the TIPM that ups the amperage for the trailer lights and starter relay draw. I can't say that unhooking the battery will reset it, but without a scanner, that is the closest thing. Good luck. Where are you at?
FMB
Nov 14, 2010 09:09 PM
12valvesmoke
Jun 12, 2009 09:46 AM
buckman361
Nov 13, 2008 09:54 AM
Paradise Racing
Jan 18, 2005 09:08 AM
MJR
Mar 16, 2003 08:26 PM
