Stalling?????????
Old Apr 13, 2006 | 05:23 PM
PMTOOT's Avatar
Stalling?????????
On the way around town today I experienced what seems to be a stall several times. I was going around 45 and then it seems as though the pedal would not do anything. I let off the pedal and waited a second. I could then depress the pedal and it would catch up. It did it several times and then I changed the fuel filter. It seemed better for a while and then it did it again. The truck has no mods and 96000 miles with an auto trans. HELP? I have an appointment at the dealer tomorrow. I could not get any codes on the dash.
Old Apr 13, 2006 | 06:40 PM
PMTOOT's Avatar
Sorry, guys. I checked the codes again and got a 1693. I rweckon they will tell me tomorrow what is the cause but it has me worried.
Old Apr 13, 2006 | 06:53 PM
Bob Wagner's Avatar
is your truck a 99? sounds like your injection pump is on its way out.
Old Apr 13, 2006 | 07:20 PM
PMTOOT's Avatar
It is a 2001.5
Old Apr 13, 2006 | 07:28 PM
Bob Wagner's Avatar
the symptoms that you are describing is know as dead pedal. If you have any 5yr/100k warranty use it. If not find a local shop. Should be much les $$
Old Apr 13, 2006 | 07:35 PM
PMTOOT's Avatar
I don't have an extended warranty. Will the 5yr/100 powertrain warranty cover it?
Old Apr 13, 2006 | 07:39 PM
Bob Wagner's Avatar
Yes, If its still within that period. It could also be an apps problem. Know your rights and dont let the dealer give you a run around.
Both items are not cheap
P.J's Avatar
P.J
Depends on the "in service" date.
As long as your truck wasn't sold to it's first owner before 4/14/2001, you'll be okay (* and you have under 100K on)
Good Luck.
Get a fuel pressure gauge.
Old Apr 13, 2006 | 07:44 PM
PMTOOT's Avatar
In service date 10/01/01.
Old Apr 13, 2006 | 07:46 PM
P.J's Avatar
P.J
Congratulations, you just saved about $2,100 per my dealer invoice in April when mine was replaced (also a 01.5)
Old Apr 14, 2006 | 11:43 AM
PMTOOT's Avatar
I took my truck to dealer this morning. He called later and said the code was a result of transfer pump failing. The part will be in Monday to replace. Gave me truck back for weekend to drive. Anything to watch out for. Injector Pump? I am hoping that if the IP fails in 10000 this will be good enough to get it replaced due to the LP. Any ideas??? By the way it is covered by the diesel warranty.
Old Apr 14, 2006 | 11:47 AM
Bob Wagner's Avatar
was the code P0216 Is the transfer pump dead or low on pressure?
Old Apr 14, 2006 | 12:10 PM
farmer dave's Avatar
I would still make sure that they check stuff out before getting it back. Even though they put a new lift pump on doesn't mean that it works. Have them check the pressure and make sure it is running enough pressure. It shouldn't go below 10 psi. I would also make sure that the injection pump is still good. Good luck!
Old Apr 14, 2006 | 01:02 PM
PMTOOT's Avatar
I called the dealer back and he said the codes that were pulled were 230 and 216.
Old Apr 14, 2006 | 01:04 PM
Since you had those codes I would make sure that they check out the ip. Might as well get everything done at once if it is bad.
