STAINS!
From: Newman Lake, WA (But my home is deep in the heart of Texas!)
STAINS!
This ain't the most interstin' post but here we go.........
Washed down the CTD last week at a local car wash. Driving home I looked at my right hand and noticed a bunch of brown gummy "tar" like stains. >
I assumed that it was from the handle of the sprayer and blew it off. When I got home and walked through a few rooms I look down and both boots had left tar prints all over my light gray carpet at home...... >
........looked at my boots and sure e'nuff....had gobs of tar or somthing on my boots and carpet......
........then, my worst fear came to light.....
.......went down and had the crud on my CTD carpet when I moved my truck prior to putting the floor mats back in!
I have dark gray flooring but it still looks awefull.. HELP! :'( Whats the best way to get that stuff out without bleaching the carpet in my truck??????? ??? Anybody have an idea of what that gunk was?
Thanks!!!!
Thanks!!!!
Re:STAINS!
I find it amusing that you are more worried about the carpet in the truck than in your house. Most of us on here are probably the same way
Try some Simple Green - after I bought my truck I lifted the mats to find grease ground into the tan carpet. Spray on a good amount of Simple Green, let it sit for a while, then scrub with a scrub brush. After that, use a rag and some warm water to lift the Simple Green & grease out. Its worth a shot.
Re:STAINS!
Hey, I remeber that stuff! I think Wally World stocks it.....
Thanks Mr. Evil........
....whooops Dr. Evil that is!
"All I WANT IS FRICKIN' SHARKS WITH LASER BEAMS ATTACHED TO THEIR FRICKIN' HEADS!!!!!"
Thanks!
Thanks!
Re:STAINS!
If the Simple Green does not work then test a SMALL area with general purpose odorless paint thinner. Use a small brush and scrub it on. Leave for only a minute then wash it out with dish detergent thinned with water. Scrub the detergent in as well. If possible wet vacuum everything out. You can also try using a can of tar remover available at Wall Mart etc. Whatever you do, test a small area first.
Let us know what works.
Re:STAINS!
Let the wife see this one,she lost it,she was mad just thinking about what you did,and wondered [If the guy is married},I was laughing so hard she got mad at me,By the way I was not laughing at your mistake,I was real sad to hear about your truck,hope all comes out ok,and you do not get into to much trouble,Goodluck Rick Oh yea,my remedy,wd-40 for the tar,then carpet cleaner for the wd-40,then carpet fresh,try in a area hidden first,Goodluck again, Rick
Re:STAINS!
Mexstan and Kandgo probably have better solutions than the Simple Green - the SG worked for me....as I couldnt use the other due to having a tan carpet. Im sure it will come out for you, if all else fails used some BUG & TAR remover.
Re:STAINS!
Thanx guys.....I'll be sure to tell my honey.........
honey......pick-up some simple green, paint thinner and Bug n'tar remover for the tar......
oh yeah, and honey....pick-up some WD-40 for the simple green and paint thinner and Bug n'tar remover ........
oh yeah, and honey...pick-up some carpet fresh for the WD-40...........
She will probably say.....honey....."leave your boot outside from now on!"
Thanx guys......will let you know what works! ;D
Over and Out!
Tom
Over and Out!
Tom
Re:STAINS!
I don't know if you can find it where you live, but there's a product called TKO Orange that works very good on stuff like that. You usually have to dilute it. Check in pet stores. Works great on dogstains on your carpet too. Gets rid of the trace smells so the dog won't go there again. Same story, test a small area first.
Re:STAINS!
Have to add my "recipe". Use some of the white lanolin based hand cleaner like "Go-JO" or "D&L" hand cleaner. You know, the white stuff you use to clean your hands after working on the truck. Put it on and work it in with your fingers. Let it sit over night if you have to.
Next day, use water and a terry cloth to absorb the residue, then use either blue majic spray capet cleaner from wal-mart (sold in the auto section) which is basically a spray with alcohol in it. (yes you can use ubing alcohol also). This will remove the hand cleaner residue.
It worked wonders for me when I had axle grease on my boots and walked into the house. Repeat as/if necessary, and always do a test spot first to make sure it does not harm the carpet. I have done this many times and have yet to have a problem. Works wonders on clothes also. Good Luck, Kevin
Re:STAINS!
You might want to try this
http://www.goof-off.com/goofoff/PRODUCTS/goormvr.html. I 've used it and it works pretty good.
Good luck
Good luck
Re:STAINS!
You guy's are GREAT! I am gonna be sure and print this entire page so that I can remember all this good advice.........
Hey....no one mentioned Oxyclean. I bet that stuff works good too! I just need to be more carefull trompin' around the house with my boots on.....can't tell you how many times I have gotten up in the morning and thought.......what on earth is that smell???? ???
Sure e'nuff....every other footstep left a nice thick smear...........
Thanks again!
Tom
Thanks again!
Tom
Re:STAINS!
Be careful with the oxy clean. It can create chemical heat and damage the carpet fibers. Also don't rub the carpet or you will "friz" the carpet fibers. Just blot the area, if you need to work whatever cleaner you use into the fibers, just use your bare fingers. Good luck, Kevin
