sqeek in right rear
Old Oct 7, 2006 | 03:19 PM
lawnpro's Avatar
sqeek in right rear
My truck sounds like the right rear is squeeking it is most noticable when slowing down then it gets louder when you press the brake then stops and comes back if that makes sense. I thought it was a brake pad problem but that didnt help. Could it be a bearing and if so how do I go about fixing it? its an 01.5
Old Oct 8, 2006 | 03:31 PM
lawnpro's Avatar
still sounds like a squeakking brake, maybe a bad caliper?
Old Oct 8, 2006 | 08:48 PM
flashgordon's Avatar
Do you have a 2 piece drive line? if so it could be your carier bearing....the support between the front and back segment of the rear drive line.
Old Oct 9, 2006 | 05:34 AM
lawnpro's Avatar
Ill look at it but I dont hear it on the left side
Old Oct 10, 2006 | 09:06 AM
lawnpro's Avatar
sometimes it sqeaks without touching the brake then I barely touch the brake it gets loud and if I push the pedal hard it goes away for a second. I just stopped using the ebrake and didnt get the squeal, so I am thinking a brake problem any tips on diagnosing it?
Old Oct 10, 2006 | 09:38 AM
Redleg's Avatar
Have you checked your U-joint. I just changed a dry one this weekend that was squeeking.
Old Oct 10, 2006 | 11:38 AM
lawnpro's Avatar
would that sound like its only in the right rear?
Old Oct 10, 2006 | 02:56 PM
Redleg's Avatar
Take a look at it real quick. Should be evident if bad, check for play. You might be surprized the way some noises resinate through these vehicles. if not one more thing to cross off.
Old Oct 10, 2006 | 02:58 PM
XLR8R's Avatar
Did you check the brake pads?
Old Oct 11, 2006 | 06:07 AM
lawnpro's Avatar
yes I changed the pads and it still squeeking
Old Oct 13, 2006 | 09:46 AM
lawnpro's Avatar
it was the front pads but when I took off the right tire and loosened the caliper the rotor was moving around it didnt do this on the drivers side is this a concern? It doesnt squeek and stops much better. Also lost a small amount of fluid up top when I was squeezing the caliper in.
Old Oct 13, 2006 | 12:18 PM
Redleg's Avatar
Your rotor is bolted to the hub, so the bearings are probably loose. Should repack them with grease with the brake job anyway.
hulmule
Mar 10, 2010 10:42 AM
jmccart
13
May 5, 2008 04:17 PM
00Dog
Sep 19, 2006 05:21 AM
CTD_Neil
Jul 11, 2006 09:35 PM
Junk Yard Dog
Mar 15, 2004 10:47 PM
