Sister's F150 Brake lights out
Old Apr 21, 2009 | 10:01 AM
Foxborough's Avatar
Sister's 2001 F150 Brake lights out
My sister lives in Port Angeles WA. They have a 2001 Ford F150 with a 5.4 Triton and the left & right brake lights do not work but the center one is still working. She says the fuses are good. My brother in law changed the bulbs last night and still not working. I don't have a schematic and my sister is more mechanical than the brother in law (which isn't too much beyond changing bulbs). But they are family and are tight on money right now. I told her to have him check for corrosion in the socket and make sure bulbs are secure in the pocket. I told her to look under the dash because I thought there may be (2) switches off the brake pedal and all she could see is "lots of wires" . Any other ideas?
Old Apr 21, 2009 | 11:29 AM
johnh's Avatar
try the ford forum
Old Apr 21, 2009 | 01:09 PM
Foxborough's Avatar
Which Ford forum would be a good start. I Googled some forums and I wasn't really impressed with any of them. I have to admit that my intrest in Ford products is about the same as my intrest in my wife's purses & shoes. But my sister is 2k miles away and want to help if I can, even if they do like Fords.
Old Apr 21, 2009 | 03:22 PM
high bid's Avatar
If there is a trailer wire harness that's been added you may want to check the connections under the back by the hitch.
Old Apr 21, 2009 | 03:33 PM
Mrlou's Avatar
Sounds like the multi function switch, wiggle the hazard light button a couple of times and see if the brake lights start working. The switch is easy to replace but you have to remove the steering wheel it is part of the turn signal assem.
Old Apr 21, 2009 | 04:04 PM
Foxborough's Avatar
Thanks guys, I told her about the ideas. They have a appointment Thursday at a dealer so if they can't fix at home at they will get it fixed then. They have something this weekend and they need the truck. Kind of bad to drive around the highway with only the middle brake light working.
surfram
Mar 11, 2010 03:15 PM
Gary Emerald
May 25, 2008 01:04 PM
mhuppertz
Apr 28, 2007 12:52 PM
Swamp_Donkey
17
Sep 6, 2003 12:20 AM
