Shorted out parking lights
Old Oct 23, 2005 | 07:00 PM
Iron City's Avatar
The lamps that are supposed to light up my license plate weren't working, so I went looking for the source of the problem. I turned on the parking lights, and they lit up, and then I went under the rear bumper with a voltmeter to test the wires going the license plate lamps. I must have touched the testing probes together while testing one of the sockets going to the license plate lights because all of a sudden the front and rear parking lamps, along with fog and cab clearance lamps went out. The trouble I'm having is I'm guessing I blew a fuse but I've checked the parking light fuse in the panel in the cab and everything looks good. Does anyone know which fuse I probably blew? And if I didn't blow a fuse, what else might have happened? Thanks!
EDIT: FIXED. Did some more searching around, the PO had a wire tap in the fuse panel, I found a fuse for that wire under the steering column. That was blown and somehow was affecting the parking lights...
Old Oct 24, 2005 | 11:09 AM
Eskimo's Avatar
my license plate lights were corroded to heck.. Wound up attaching a trailer license plate light over the hole where the OEM one went.
Glad ya got it fixed though...
Old Oct 24, 2005 | 01:20 PM
Iron City's Avatar
yeah, I guess the contacts on the license plate lights must be corroded because the bulbs were ok.
Old Oct 24, 2005 | 04:06 PM
getblown5.9's Avatar
i did the same thing once...lost my dash, tail, an parking lamps...search wires for 3 days looking for a short...only to find out there was a fuse under the hood in the "other" fuse panel that was blown
Old Nov 3, 2005 | 08:31 PM
eric13's Avatar
I had the same problem as getblown
illEatUrDuramax
Nov 11, 2009 03:51 PM
Txwelder
Feb 29, 2008 06:17 AM
craneage2001
Nov 9, 2006 07:07 AM
CHarlan
Aug 6, 2003 08:40 PM
