!!!!scary Noise!!!!!
Old Jun 16, 2006 | 01:16 AM
one54ton's Avatar
While pulling up to a friends house this evening my truck made a really odd and loud noise while slowing down in drive and while idleing in park. This noise is super loud and sounds like its coming from somewhere inside the oil pan. It also changes pitch while at a low RPM when Im hitting the throttle but goes away while over 1000 RPM. Anyone have a clue because im scared to drive it.
Old Jun 16, 2006 | 01:21 AM
H2SRDMB's Avatar
is it a knocking sound,grinding, clicking, sound of kitten being wrapped around you belts,etc... if you know its coming from your oil pan. cange the oil and look for metal shavings! use a magnet and run it thru the oil if you have to!
also have you cahnged you diff fluid in a while. thats also in the area, and it is stuck in 4wheel drive
Old Jun 16, 2006 | 02:26 AM
Jambbii's Avatar
You could possibly have a broken flex plate or sticking starter too.
Old Jun 16, 2006 | 07:59 AM
one54ton's Avatar
I will try and change the oil. The flex plate is brand new but who knows.
Old Jun 16, 2006 | 05:28 PM
Jambbii's Avatar
Check your converter bolts too.
Twangster
Jan 24, 2011 11:01 AM
Stamey
Feb 21, 2005 07:26 PM
CAPTCOOL
May 8, 2004 10:20 PM
hotdram
Aug 14, 2003 03:07 PM
thumper 549
Aug 10, 2003 10:10 PM
