right rear brakes burning
Old Sep 21, 2010 | 04:46 PM
fastlane's Avatar
A couple of weeks ago I did the rear axle brakes on my '05 ram 2500 single axle. I replaced the left caliper and turned the rotor. I replaced the right rotor, but kept the caliper (it looked newer and all the rubber was in tact) I bled the brakes, all 4 wheels. Today I smelled the brakes burning on the right rear, what would cause this to happen? I can't see yet if there is air in the line (wifes not home!) I need this fixed tonight, the truck works tomorrow. Should I just get a new caliper, although it looks newer it does have chrysler logos on it.
Old Sep 21, 2010 | 07:24 PM
Mexstan's Avatar
When you replaced everything, did you use high temp grease on the slides and bolts? it sounds like a slide (or guide) is sticking. Another thing that could cause this is a sticking piston.
Old Sep 22, 2010 | 10:09 AM
infidel's Avatar
A brake hose with a collapsed inner lining can also cause the same problem.
The loose lining can form a flap inside the hose acting like a one way valve not letting the pressure release. More likely to happen when the hose is moved around when work is being performed.
HorseHauler
17
Feb 23, 2010 02:46 PM
MX429
54
Jul 19, 2007 03:48 PM
00Dog
Sep 19, 2006 05:21 AM
wildcargo
Nov 29, 2005 04:20 AM
Junk Yard Dog
Mar 15, 2004 10:47 PM
