Replaced the steering box and still........
Old Aug 7, 2006 | 02:47 PM
NSJ15332's Avatar
I replaced the steering gear box on my 1997 2500 dodge diesel. The reason is because my steering would lock up when driving at low speeds and making sharp right turns. After I replaced the box, soon after, the steering would lock up again. And now after driving for about an hour straight, I hear a humming nosie from the front. Is this a power steering problem or is it something else?
I checked the PS Fluid and it is fine, and there are no leaks anywhere.
HELP!!
Old Aug 7, 2006 | 06:17 PM
RCW's Avatar
RCW
Assuming your new or rebuilt steering box was properly adjusted, I would expect your pump is due for replacement. Never use a used and unrebuilt steering box or you will trash your pump from crap picked up when the pump first charges the used system. If the latter happened replace both the pump and the steering box, and your brake accumulator to avoid a catastrophic accident.
Old Aug 8, 2006 | 08:10 AM
NSJ15332's Avatar
No rebuilt box, I bought it new from NAPA. What would the nosie be from?
Old Aug 9, 2006 | 04:10 PM
mwolfe's Avatar
Does The Truck Have A Steering Stabilizer Shock If So Make Sure It Is Not Binding
nfc90
Apr 20, 2012 04:06 PM
ramlovingvet
Feb 9, 2011 10:14 PM
mega-engr
Dec 14, 2007 10:42 PM
kevellis32
Mar 25, 2007 08:54 PM
