rear end trouble
Old Feb 6, 2003 | 06:21 PM
miful's Avatar
rear end trouble
i have a 92 gen1 250 4 wd ext cab lb and i have been having trouble with the rear axle i think its is locked into posi and when i turn it grumbles and is wearing my tires very fast i have had the oil changed and put new additive for the posi and no help so far thanks mike
well here is a follow up on the problem took it to rear end shop 347.00 later all fixed it was the clutchs they were metal to metal and would bind up around corners. thanks for the advice mike
Old Feb 6, 2003 | 06:33 PM
BigK's Avatar
Re:rear end trouble
Sounds like it could be a few things. <br>Without better &quot;noise description&quot;, it could be carrier bearings, or pinion bearings. Could be gear wear. Could be that the clutches have worn out, and &quot;welded&quot; together, thus allowing little slippage when cornering. <br>Bottom line is find a good shop, and get it in for repair,(bring your wallet), before it gives totally up, and breaks more parts, while leaving you stranded.<br>Most folks don't have the tools, knowledge, or patience to properly set a Dana carrier. Difficult, but once done right, it'll last for a long time.<br>
Old Feb 11, 2003 | 05:12 PM
quantrill88's Avatar
Re:rear end trouble
if u didnt buy ur rig new, someone may have welded the clutch packs together to make it act like a spool, (not the best idea in the world for obvious reasons, lol), ive seen others do this and breakage is usually the result, might be wrong, just thought id give my 2 cents and agree with BigK
ridlangus123
Dec 30, 2013 08:36 PM
1999blackcloud
Jan 26, 2010 08:52 AM
doorguy
Jun 8, 2007 06:19 AM
Fishbait
16
Jan 29, 2006 03:24 PM
royta
Jul 13, 2004 06:54 PM
