Quadzilla Problem????
Ok I put the Quadzilla On my 99 CTD. I taped into the IJP Wire with the supplied terminals and Soldered the Wires, then crimped them both the IJP and the TPS sensor. Hooked up the Map sensor and ran the wires threw the Firewall, VERY carefully to make shure I didnt cut any wires and zip tied all of them away from sharp and hot objects. Well Hooked up the ground and put the power wire in the fuse box where they wanted it.
Turned the key on let the moduale make it cycle it was, red green green red. Was all good. Cranked the truck up check all my connections. Took it down the road, had power from the start I get about 6 or 7 Miles down the road to a store. Noticed my truck acted like it was missing. It all of a sudded cleaned up and when I have it on any level I have stock power untill 1500 RPM. Then BOOM it takes off. or if i am crusing on any power level and it gets to 1500 it starts to jump a little untill you get over 1500 but there is no different in the sound pitch of the engine when its at idle when you change power levels.
DOES anyone know what on earth is goin on?
mopar440cu
Nov 21, 2015 08:39 PM
norcaljr
13
Aug 5, 2008 10:13 AM
Smokin98.5
0
May 29, 2008 05:35 PM
edtyler
Oct 12, 2006 03:09 AM
MoreSmoke
20
Jan 7, 2004 06:07 PM
