Problems after KDP Fix
Old Jul 28, 2003 | 06:38 AM
WalkingHorse77's Avatar
I finally took a look at my pin ( I had A bad oil leak ) . Good news is that is KDP was fine. The timing cover was just loose. I installed a new crank and timing seal. Now when the truck heats up there is a loud squel coming from the front the front of the motor. Anyone have any ideas what this is coming from? Thanks again for any feedback.
Old Jul 28, 2003 | 06:57 AM
finallydiesel's Avatar
Re:Problems after KDP Fix
Sounds like your belts aren't tight enough. Had the same problem
Old Jul 28, 2003 | 03:08 PM
Barney's Avatar
Did you lose any of the fluid in the fan clutch during the Pin job?<br>
Old Jul 28, 2003 | 03:27 PM
Haulin_in_Dixie's Avatar
When a fan clutch is off the vehicle it should always be put on its front or it will lose oil.
Old Jul 28, 2003 | 09:33 PM
Stamey's Avatar
After mine was done, for unknown reasons, I had to replace my belt. The belt on there only had about 12K on it, but it started making all kinds of noise about 100 miles after the KDP. I know the belt got nothing on it because I stood there taking pics while it was done. It was the weirdest thing that it just started making noise, especially since the tensioner is an automatic one, not like the tension was different after the job. <br>Put a new belt on and it shut up. ???<br><br>Chris
Old Jul 29, 2003 | 08:40 PM
thumper 549's Avatar
It's my vote too , the belt was put on so it runs the opposit direction , it dose not like it.
To prove it squirt a little greasy stuff on it wd40 or what have you ,bet the noise stops.
Old Jul 30, 2003 | 07:07 AM
THANK YOU !
I switched the belt around and put some belt dressing on it. And it was quiet, well as quiet as a diesel can be. Thanks again for everyones help.
Old Jul 30, 2003 | 03:13 PM
dsldan's Avatar
One thing to remember, with the newer 'S' tyle belts many are setup to go in one dirrection only, and reverving them may cause problems.
Old Jul 30, 2003 | 07:27 PM
Bearfoot2's Avatar
[quote author=Gary - KJ6Q link=board=13;threadid=17607;start=0#msg165971 date=1059597777]
Yeah - the engine might start turning over the wrong way - just think - I'd have one gear forward and 6 in reverse...
And I'd hafta DRAIN the fuel tank every 600 miles...
[/quote]
;D ;D ;D ;D ;D ;D
sootnsmoke
Jan 5, 2012 08:55 PM
Smokin96_12v
Oct 12, 2009 07:39 AM
Rickcher
Jul 13, 2009 01:22 PM
bkay
Mar 12, 2003 06:44 PM
pappyman
Dec 3, 2002 02:34 PM
