pritty sure its fuel related
Old Oct 27, 2004 | 09:50 AM
grinch's Avatar
OK im new to diesel... I went out to warm the truck up this morning and it ran for about 30 seconds and then died. checked the fuel relays they are all good. Cracked the injectors cranked the ignition no gas.... Bad fuel pump???? there is what I believe to be a second pump by the engine it has a drain on the side. It will hum when I try to start but I do not hear the normal pump like I normally do..... If this makes any sense please help...
thanks in advance.
Bryan
Oh yeah its a 99 2500 if that makes a difference.
Old Oct 27, 2004 | 10:12 AM
grinch's Avatar
Ok now that I have a little more light outside I realised its not the waterseparator that vibrates when I turn over the engine its the small pump inline before it.... Is this the main fuel pump??? I need a repair manual but have no way to get one to help me trouble shoot whats going on....
Old Oct 27, 2004 | 10:13 AM
cumminsboy's Avatar
Maybe the dreaded injection pump that are so famous about "breaking". Somebody else will chime in and give some more info though. Welcome to the site anyways. cumminsboy
Old Oct 27, 2004 | 10:46 AM
grinch's Avatar
Ok I just pulled the fuel inlet and outlet lines off of the water seperator and cranked the engine. I got zero fuel out of them... So in my thinking even thoagh the lifter pump is vibrating its bad. Is this correct thinking or am I out in left field?
Old Oct 27, 2004 | 12:47 PM
Copenhagenjunkie's Avatar
Yes it is possible for the pump to "run" but not pump anything. Instead of cranking just "bump" the starter- the lift pump should run for around 15 sec. This way is much easier on your starter.
Since you pulled the outlet lines and cranked you did suck air into the system but I am afraid you have a bad lift pump anyway.
When you get a new lift pump only open the small brass plug closest to the front of the engine ontop of the fuel filter housing.
Then bump starter until you get fuel out of it. Tighten it up and then bump starter several more times before you crank to fire it up.
FYI- get a fuel pressure gauge.
Your injector pump (vp-44) may go kaput in the very near future.
Karl
Old Oct 27, 2004 | 03:19 PM
nitrousn's Avatar
are you sure there is fuel in the tank?
Old Oct 27, 2004 | 03:27 PM
grinch's Avatar
Yep it was the lifter pump... guess I better get some gauges to let me know if the dreaded vp 44 goes out....
Thanks guys
Old Oct 27, 2004 | 03:47 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Make doubley sure there is fuel in the tank.
How many miles since the last fillup?
The fuel tank gauge sending units are famous for going Tango Uniform.
Old Oct 27, 2004 | 03:54 PM
cumminsboy's Avatar
I don't know why, but that's just funny, good one Shovelhead!!
Old Oct 28, 2004 | 08:30 PM
grinch's Avatar
I know it wasnt the tank.... I filled up the night before...
Now im super parinoid about the darn injector pump going out...
oh well its only hard earnd money right???
Old Oct 29, 2004 | 05:46 AM
Shovelhead's Avatar
Are you under 100,000 miles.
If so, Cummins warranty might help you out.
Old Oct 29, 2004 | 02:02 PM
Haulin_in_Dixie's Avatar
It's a '99, you have two 1/8 npt plugs on top of the filter, pull one out and turn on the ign. If it is working well you will shower the engine with fuel. If nothing comes out you have lift pump problems.
Old Nov 1, 2004 | 10:17 PM
grinch's Avatar
Nope murpheys law is in order on that one... 105,000 Miles is it....
Oh well I learnd alot about my truck on this one.... Guess I had better take it as a good learning experiance.
Old Nov 1, 2004 | 10:55 PM
crobtex's Avatar
Re: pritty sure its fuel related
thanks in advance.
Bryan
It's probably that "gas" you put in there.
Only kidding......
Old Nov 2, 2004 | 01:56 PM
mamm7215's Avatar
Codes?
Get your codes read at Napa, Autozone or the Dodge dealer near you. If your lift pump failed and/or your VP44 is going, there will likely be codes set. If you see P0216, your VP44 is gone or going to die shortly.
Doug55
Sep 13, 2009 08:20 PM
nelly
Apr 25, 2008 12:14 PM
sharkbaitracing
Mar 18, 2008 01:10 PM
Diesel Dummy
Sep 28, 2006 08:25 AM
John Rodriguez
Sep 28, 2005 11:46 AM
