plug in temp.????
Old Jan 29, 2003 | 07:17 PM
calvin's Avatar
plug in temp.????
How low should the temperature go before I plug this thing in?? 2003 2500 <br>Thanks
Old Jan 29, 2003 | 08:38 PM
MnTom's Avatar
Re:plug in temp.????
I plug mine in when the temp outside is going to be about zero. You can plug it in anytime you want and it will start much much easier. I also have mine on a timer so it will start getting power to the heater about 3am and when I start it about 7am it starts right up even at minus fifteen.<br>Tom
Old Jan 29, 2003 | 08:51 PM
Dieseldude4x4's Avatar
I plug mine in when temps are going to 20 or below. Some times, higher but it depends on what you want.
Old Jan 29, 2003 | 10:13 PM
Redleg's Avatar
I would say below freezing. Just in case there is any water anywhere.... fuel, bad coolant mix,etc.
royta
Nov 25, 2016 11:48 AM
ctturbodiesel
Dec 13, 2006 09:37 AM
firesine
Nov 24, 2005 10:58 AM
dvp98.5
32
Jan 22, 2004 11:02 AM
