p2149 ?
Old May 29, 2010 | 08:12 PM
FullSize2500's Avatar
p2149 ?
2006 model throwing p2149......Need some input on this. Checked the connections, ohmed out all the injectors(all within limits). I was going to replace the valve cover gasket in hopes that would correct the problem next. I know that the injectors are working electronically, could there be a malfunction there with the injector itself? How would I check that? Anyway, I thought about taking it in to have the ecm reflashed at Dodge under this latest recall to see if that's what the problem is. I have been running a Bully by the way. Any input is appreciated.
Old May 31, 2010 | 09:56 PM
BigIron70's Avatar
Cummins Guru
Were all the injectors exactly same resistance value? They are usually at .2 ohms. I have also seen the wires in the valve cover gasket cause this code to set. Did you use a digital ohm meter?
Old Jun 1, 2010 | 06:25 PM
There were variations. It calls for between .5 and 1.5 I thought.
Cylinders 1 and 2 (.5)
3 (.8)
4 (.5)
5 (.5)
6 (1.2)
I also tried moving the harness while the truck was running and changed the gasket. No luck yet.
Old Jun 6, 2010 | 06:59 PM
BigIron70's Avatar
Cummins Guru
Should be less then 1 ohm, I have always seen .2 ohms on good injector.
haulin-rv
Oct 17, 2008 10:39 AM
redgoat05
Sep 13, 2007 12:52 AM
RockcrawlingTJ
Oct 29, 2006 10:41 PM
Merritt
14
Aug 6, 2006 09:27 AM
