P0628
Old Jan 6, 2009 | 04:58 PM
dieselpower04's Avatar
P0628
can anybody tell me what that is. i'm thinking fuel pressure(fuel pump is toast). cranks but won't start.
Old Jan 6, 2009 | 05:09 PM
John Faughn's Avatar
I come up with ,
fuel pump relay circuit low [ or ]
fuel lift pump control circuit low
You need to see if the correct voltage & ground at computer for fuel , then see if they are correct at relay , then check at pump , remember that grounds need to be good at all these locations .
If you have the equipment , see what kind of AMPs the fuel pump is pulling , if it is getting good ground & power .
You mentioned pressure , what is it ?
Old Jan 6, 2009 | 05:33 PM
thanks john! I called the dealership and lucky me it's under the cummins engine warranty.
Old Jan 6, 2009 | 05:44 PM
Totallyrad's Avatar
That's the lift pump. When mine went I got that code and one other about rail pressure high. The emissions warranty will cover 100k/5 years I believe. If you bought an extended warranty and it's still in effect, your tow may be covered along with a rental.
Raspy
Dec 22, 2016 06:34 PM
FishingFather
Apr 17, 2007 12:28 PM
brockstar
Feb 13, 2007 10:07 PM
DirtEater
21
Feb 6, 2007 06:26 PM
973604x4
Jun 14, 2006 11:11 PM
