p0237 and limp mode
Old Apr 2, 2008 | 11:00 PM
WhozNxtLS1's Avatar
p0237 and limp mode
Hey, I attempted to install a smoke switch last night on my 05 CTD and it has a smarty jr, and 5" turbo back exhaust.
Now I took everything off as it didn't seem to work and set the map wires back to stock, and now I have a p0237 code and the truck is in limp mode because it has no power at all. I try to reset it with the smarty jr. and the code won't reset, just stays present.
How can I fix this, and or will the code go away
Well here's the deal. Originally I had wired the two wires together and into a switch, but a switch with power and ground. I tripped 8 codes, and then reset them, but 1 stayed on. a P0273 code. It's a MAP sensor low voltage code. Well I rewired everything to how it was before, and now the truck is in a limp mode, and won't kick out of limp mode. I re-spliced the wires to ensure a good connection, and nothing. I can't seem to get rid of this code.
Could it be a fried MAP sensor
Thanks
Chris
Old Apr 3, 2008 | 04:48 AM
dozer12216's Avatar
And it could be a fried ECM also.
Old Apr 3, 2008 | 08:58 AM
WhozNxtLS1's Avatar
Wouldn't there be more codes present if it were a fried ECM? I know on Honda's if you fry the ECM then you have many more codes present
Old Apr 3, 2008 | 10:27 AM
Bob Wagner's Avatar
i would try a new map sensor
Old Apr 3, 2008 | 10:56 AM
Dinner's Avatar
That is for MAP Sensor Voltage Too Low...I had my check engine light come on in my 99 last night, dead pedal, wouldn't go anywhere at all. Ran through the truck with a scan tool today to find..
DTC Detected in ECM
Map Sensor Voltage Too Low (the P0237 code I believe)
Soo I cleared the codes, truck instantly got it's rpms back and I drove around, and so far so good! But I will go to work early to clean my Map Sensor..hopefully that will help.
Dinner
03 Melt Down
May 31, 2022 12:49 PM
missouriman
33
Sep 19, 2012 08:10 PM
thenrie
Jun 29, 2011 12:12 PM
fahtb0y
Dec 17, 2009 07:32 PM
Efretwell
Oct 31, 2006 12:58 PM
