24 Valve RockerArm Lock Nut Torque Specs
I just adjusted my valves.
Im fixing to leave the house and I went by this guide
https://www.dieseltruckresource.com/...n&onlynewfaq=1
it says to tighten the locknuts down to 18ft lbs of torque which seems too little.
Is that right? I just wanted a quick yes or no answer before I go on a long trip.
Thanks
Thanks
My Haynes manual, which i keep on a roll in the bathroom, just says to "tighten the locknut securely then re-check the clearance.." The rocker bolts themselves are spec'd at 27 ft lbs but that is for the bolts holding the whole assy. down.
1985cucv
Aug 2, 2014 12:01 PM
Clane
Jun 2, 2012 03:31 PM
Firstgenfanatic
May 14, 2008 06:17 PM
