p0069 Help
Old Aug 12, 2008 | 10:48 AM
ssleeper94's Avatar
p0069 Help
i was on the hwy yest and i floored it and it moved like a slug, then the cel came on i checked it was p0069. i searched the forums couldn't really find anything on it. what should i do its an 05 6spd w/ tst and smoke switch. the boost gauge on my tst reads 30-40psi even at idle. i noticed that one of the wires of the smoke switch fell off and were resting on metal, can this of shorted it out to the map. any ideas or off to dealer for warrenty work.
Old Aug 12, 2008 | 10:55 AM
johnyb59's Avatar
Its a map sensor fault. reattach your wire or isolate it and see if that helps out.
Old Aug 12, 2008 | 11:04 AM
ssleeper94's Avatar
also forgot to mention i have the passenger side battery out i had to use it in my race car and i forgot to put it back in can that have anything to do it
Old Aug 13, 2008 | 07:08 AM
Coagulation's Avatar
Muted User
Thats a hell of a battery to be putting in a race car lol, anyways it is something with the map sensor circuit, you gotta look at the circuit and where the TST taps into it.
Old Aug 16, 2008 | 02:51 PM
ssleeper94's Avatar
ttt anyone?
Old Aug 16, 2008 | 03:27 PM
w.tx iceman's Avatar
Like everyone has said,cel will go away after a few starts. I have the same problem with my painless striker box intermittently shorting on the map hookup, no power and the cel for a few starts. Put everything back and check connections and you should be ok
2500RedRam
Jun 1, 2007 09:28 AM
TE-44
May 8, 2006 01:19 PM
grandblanc
Jul 25, 2005 11:06 AM
ggades
13
Apr 17, 2004 12:56 PM
