overboost sensor
Old May 8, 2006 | 05:11 AM
dieselbeef's Avatar
Muted User
overboost sensor
codes says it no good. 238 i think...or 236 . anyways where is it and will it give me the same driveability problems as a bad vp. although i do get the 216 code as well. also cant erase the codes even with a obdII scanner. says communication problems. different software needed for the diesel?
Old May 8, 2006 | 09:57 AM
Copenhagenjunkie's Avatar
That would be the map sensor. Your wastegate is probably stuck open. Should be able to erase codes w/ obd2. Sounds like your vp is toast if your having driveability problems.
Old May 8, 2006 | 10:40 AM
dieselbeef's Avatar
Muted User
**** i was hoping to get out of the vp but dont look that way...im off to southeast power....waaahhhh!!!
Old May 8, 2006 | 04:44 PM
WSA308's Avatar
The boost sensor is located on the top of the intake manifold between the ram and the firewall. My truck was sluggish and had poor throttle response until I replaced the boost sensor, it was like night and day.......until my injector pump bit the dust...been in the shop now 15 days waiting on Dodge Engineering to make the diagnosis....first they said injectors, replaced all six and still would not start, I told them it was the injector pump, they said pump tested OK, two days later they told me that they think it is the injector pump?????
Old May 8, 2006 | 05:15 PM
phox_mulder's Avatar
Boost sensor is located in different positions in 2nd gen and 3rd gen vehicles.
The OP needs to let us know what vehicle he/she is driving.
phox
Old May 8, 2006 | 06:15 PM
WSA308's Avatar
Good Point.
Old May 9, 2006 | 06:48 AM
dieselbeef's Avatar
Muted User
signature up dated. ram o2 auto. ez box strsaight pipe. filter kit
johnshole
0
Jul 13, 2005 10:42 AM
high country
Mar 24, 2005 10:52 AM
seabee
Feb 28, 2005 02:50 PM
psalm69
Sep 13, 2004 06:34 PM
spacely
Feb 28, 2004 01:10 PM
