Old Diesel???
Old Feb 2, 2007 | 10:46 PM
deezlfitter's Avatar
Old Diesel???
Last spring I purchased about 200 gals of diesel and I stored it in a 200 gal tank. I added about 8 oz. of stanodyne and sealed the tank. Wondering how long it will keep without giving me problems? Any body know? Thanks.
Old Feb 3, 2007 | 05:27 AM
AlpineRAM's Avatar
In the Austrian military the storage time for diesel fuel is 15 years. (With a storage conditioner) You'll need to be careful about water in the fuel due to condensation in the tank- if the tank is accessible from the top you can make a pickup float of 2 metal canisters and put the suction hose only 2" below the canisters and siphon it out. This way you won't agitate the fuel and the water and sludge stay on the ground and you get clear diesel.
HTH
AlpineRAM
Old Feb 3, 2007 | 05:37 AM
HayHauler1's Avatar
Question... I have an old 1960 Mercedes diesel in the garage. The fuel has been in the tank for 8-10 years. Is there any way to condition that fuel, or should I just drop the tank and discard it? Could pour it around the fence line to kill the weeds/grass under the barb wire fence I guess....
Just thinking of trying to get that old car started again...
Inline 4 cyl diesel.
Hay
Old Feb 3, 2007 | 06:53 AM
AlpineRAM's Avatar
I think it's gonna be more important to remove the glow plugs and squirt in some penetrating oil before you even try to turn the engine over. After letting the oil soak for some days turn the engine with glow plugs removed slowly with a wrench. I'd discard the fuel because it may well have formed algae. New fuel filter and maybe new fuel hoses (depending on the state they are in)
HTH
AlpineRAM
Old Feb 3, 2007 | 11:02 AM
Thanks Alpine. Good advice. The pick up in the tank is about 2" above the bottom and I also have a 5 micron fuel and water filter on the transfer pump.I will keep an eye on it. Thanks again.
Old Feb 3, 2007 | 11:44 AM
TIMMY22's Avatar
it can go sour after about 5 years.
you can add "Sta-Bil" to it like gasoline.
Old Feb 3, 2007 | 04:51 PM
infidel's Avatar
A friend's company did a salvage job on on some WWII barges in Seattle.
They brought back several thousand gallons of the 50 year old diesel and used it to run heavy trucks and equipment without problem for many years.
Old Feb 3, 2007 | 09:06 PM
TIMMY22's Avatar
bill, I think the older fuel was made much differently than todays fuel giving it a better shelf life. here's some reading.
http://answers.google.com/answers/threadview?id=479588
http://theepicenter.com/tow021799.html
http://www.el-cerrito.org/fire/power_safety_issues.html
Old Feb 6, 2007 | 12:27 AM
AlpineRAM's Avatar
Oops, I think we must have completely different fuel over here.
The shelf life minimum requirements are quite high- IIRC it's 5 years for diesel and 10 years for heating oil.
AlpineRAM
Dodgezilla
Nov 6, 2011 04:13 AM
chariotdriver
Oct 18, 2008 10:50 PM
Mark Hodowanec
Apr 18, 2007 06:11 AM
pet05
Jun 14, 2006 10:00 PM
kandgo
Dec 28, 2003 01:34 PM
