Oil out, where to put it in?
Old May 5, 2003 | 03:04 PM
dodgeman01's Avatar
I'm doing what they told me to do here.<br>http://www.dodge-diesel.org/yabbse/i...threadid=14014<br>8th post down. They told me to take the rear section of the transfercase off. Well I did and oil came out. So where do i put the oil back in??? And what kind of oil do I use?<br>DM01
Old May 5, 2003 | 04:29 PM
Ruralmedic's Avatar
Re:Oil out, where to put it in?
There should be both a fill and drain plug on the back side of the transfer case. The New Venture 241 on my truck takes ATF. I assume your '94 has a New Process 241, I don't know if that calls for ATF or gear lube. Check your owner's manual if you have one. I was always told, if the transfer case has an aluminum housing, it takes ATF. If it's a cast iron housing, it takes gear lube.
barngal6
Jul 5, 2009 06:49 PM
dieselcarpenter
Jan 26, 2008 09:33 PM
adamkn
Jan 2, 2008 09:09 AM
Harold Swanson
Mar 7, 2007 08:49 PM
