Oil change
Old Feb 6, 2004 | 01:11 PM
joeca12's Avatar
Oil change
What size and type of tool is used to take the oil plug out?
Old Feb 6, 2004 | 01:34 PM
dodgediesel4x4's Avatar
well im guessing you have a CTD, a standard 3/8" socket wrench is used. Please fill in your singature so others can help you in the future.
Welcome to DTR!!
Old Feb 6, 2004 | 01:46 PM
joeca12's Avatar
I have a 2001 3/4 ton Diesel, The plug does not look standard to me. A socket would not work because there is nothing to place the socket on. Some type of allen wrench. The plug is flat with a square like hole in the middle.
Old Feb 6, 2004 | 02:08 PM
joeca12's Avatar
Old Feb 6, 2004 | 02:16 PM
billg's Avatar
You don't need a socket just the square end of the ratchet or extension.
Old Feb 6, 2004 | 02:25 PM
Shovelhead's Avatar
Administrator / Scooter Bum
The hole in the plug is a 3/8" square drive.
Just use your 3/8" ratchet in the hole.
Old Feb 6, 2004 | 03:05 PM
kandgo's Avatar
And do not over tighten when going back, as some have striped thiers. I believe the torque has been readjusted to 40 ftlbs?? Someone correct me if I am wrong, as I still drive a old 2nd gen. Goodluck,,,, Rick. Oh yea, welcome to the greatest web site for your Dodge diesel!!!
Old Feb 6, 2004 | 03:23 PM
Shovelhead's Avatar
Yeah you gotta watch that torque spec.
Some older books say it's 60 ft/lbs.
After many stripped pans they changed it.
I don't personally use a torque wrench on mine.
I just make it GNT.
Good-N-Tight
Save the 800 pound gorilla routine for the lug nuts.
Old Feb 6, 2004 | 03:26 PM
joeca12's Avatar
Thanks everyone. I did not know there was a site like this out here. I will be visiting more often since I am new to my diesel engine.
Old Feb 6, 2004 | 03:56 PM
P.S.----If you decide to torque it down with a torque wrench and you do use an extension, make sure you look at the chart in the instruction booklet that came w/ the wrench (if you still have the bookelt) b/c when using extensions, they throw off the exact amount of torque applied. I'm just picky like that and I HAVE to be exact. Just a tip and my $.02.
Hunter
Old Feb 6, 2004 | 11:40 PM
figure_9_pro's Avatar
Get rid of the drain plug and put in a Fumotovalve and it won't be a problem again....
http://www.fumotovalve.com/
Old Feb 7, 2004 | 07:39 PM
Bio's Avatar
Bio
What is a Fumotovalve, and what is the benefit?
'99 2500
Old Feb 7, 2004 | 07:59 PM
Shovelhead's Avatar
'99 2500
Click on the link in his post.
Old Feb 9, 2004 | 12:17 AM
Dr. Evil's Avatar
Joe, here are some really good tips for changing your oil for the first time:
http://dodgeram.org/tech/dsl/filter/oil_filter.htm
http://home.austin.rr.com/murdocks/oil.htm
http://dodgeram.info/tsb/2001/09-004-01.htm
I hope this helps.....
Old Feb 10, 2004 | 08:59 PM
rail roader's Avatar
I HAVE A 2000 DODGE DIESEL AND MY OIL PLUG TAKES A 3/8 RATCHET END NOT A SOCKET.
