O my "L"
Old Apr 1, 2003 | 11:14 AM
hvanflee's Avatar
O my "L"
About a month ago I had a new/used engine install in my truck, but the problems continue. :'(<br><br>Check out this picture and guess where I found this 3 inch clamp? :'(<br><br>See next message for a clue.
Old Apr 1, 2003 | 11:20 AM
hvanflee's Avatar
Re:O my "L"
OK, now for the clue. ??? Yes you guested it, my mechanic left it in the air intake hose. A you can see by the very bad picture I have chipped of the ends of 3 turbo fins. Now the question is ??? where are the pieces and do you think they could have caused engine damage? Do you think they could still be trapped in the inner cooler? How much will it cost to have the turbo rebuilt? What should I do? <br><br>I am looking for suggestions, thanks,
Old Apr 1, 2003 | 11:45 AM
hellotbone's Avatar
Re:O my "L"
I have no Idea but I think I would be burning that mechanics house down &gt; that is terrible! I cannot even believe I just saw that picture!
Old Apr 1, 2003 | 11:49 AM
hvanflee's Avatar
Re:O my "L"
I do have more question, do you think it will harm the turbo to drive it like that? Also is it an easy job to rebuild the turbo?
Old Apr 1, 2003 | 11:59 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:O my "L"
I can only imagine how out-of-balance that turbo is in that condition, and think of it spinning at several thousand rpm
I wouldn't be driving it like that.
Old Apr 1, 2003 | 01:18 PM
Superduty12v's Avatar
Muted User
Re:O my "L"
The turbo ain't going to get any better but the damage to it is done. I wouldn't worry about driving the truck with the turbo like that... but it's surly not what it should be.
Old Apr 1, 2003 | 01:55 PM
hellotbone's Avatar
Re:O my "L"
I'd worry about it that thing will be out of balance huge and will take out the bearings and come apart for sure!
Old Apr 1, 2003 | 02:10 PM
Mexstan's Avatar
Re:O my "L"
Any damage that that the missing pieces will cause has been caused and probably nothing else will happen to them. However, I would expect that the turbo bearing life will be drastically shortened unless the missing pieces are diametrically opposite one another, in which case the unbalance will not be as bad.<br>Can't you go back to the mechanic or shop and complain? What about warranty?
Old Apr 1, 2003 | 03:34 PM
dodgeram's Avatar
Re:O my "L"
I would take all the intercooler lines and see if you can find the peices .........if you're lucky they havn't made it to the engine yet<br><br>as for the turbo .........get it replaced before it grenades and sends lots of little pieces into your engine ............<br><br>big time at the shop you got the work done at........they should cover the turbo replacement .........and get them to replace the intercooler too cause the pieces may be lodeged in there just waiting to come loose at a later date<br><br>
Old Apr 1, 2003 | 03:52 PM
Redleg's Avatar
Re:O my "L"
I just ahd mine rebuilt locally for about $350. Not the same turbo as yours but, while in the shop, I have heard him give the same quote to other clients on the phone. I'm sure they weren't all 1st gen Cummins. They can improve the flow with alittle extra cash as well. I'd love to have one from Piers or somebody, but a rebuild was half the price, and it'll be a while before the engine will be able to make use of an upgraded turbo.
Old Apr 1, 2003 | 04:07 PM
hvanflee's Avatar
Re:O my "L"
Anyone have experiance rebuilding there own turbo? The parts are about $170. Should I try it myself or should I give the mechanic another try?
Old Apr 1, 2003 | 04:20 PM
95ramtough's Avatar
Re:O my "L"
Man I wouldn't let that mechanic touch it again, unless he fixes it! Can't you get Turbos for cheap off e-bay.
Old Apr 2, 2003 | 06:54 AM
hellotbone's Avatar
Re:O my "L"
You can rebuild yourself BUT you must have it rebalanced after you touch it.
Old Apr 4, 2003 | 08:36 PM
MnTom's Avatar
Re:O my "L"
The best advice that I can give you is to call Piers. www.piersdiesel.com He will give you a straight answer about your concerns.<br>Tom
Old Apr 4, 2003 | 09:35 PM
Sootblower's Avatar
Re:O my "L"
I would not drive that truck until the turbine blade is replaced and balanced. I bought the rebuild kit for my 91.5 and the instructions are very specific about absolutely no damage to the blades. You can rebuild a turbine with good blades without re-balancing only as long as four seperate parts are properly marked, maintaining exact balance when put back together. I would assume that your bearing will be wiped (metal to metal) due to the imbalance. The kit was $100 cdn but assumes all blades are perfect condition. The instructions are so specific that you can only use a bristle brush and NOT a metal brush when cleaning soot off the turbine side. Here is the link for getting the re-build manual, looking up &quot;parts and service&quot; then &quot;service literature&quot;. Be patient as this site uses flash software and takes time to present things in its own slow way. The download is pdf file and is speedy. Note that the compressor blade has LEFT hand thread nut!
Holset site
