NV4500 issue
NV4500 issue
I towed a small car yesterday about 800 miles. In the last stretch of my trip I lost fifth gear. I exited the freeway and the trans was making a rattling noise. Every other gear worked. Then fifth came back...but the noise scared me too much to drive it any further.
what should I do?
what should I do?
never known 5th to comeback once ive lost it. had it strip on my 01 where unless it had a load it would work. best thing to do is pull the transfer case off then pull the tail off it use a 12point socket its a 10mm then look at the nut and gear
Big deezul, what probably happened is the 5th gear nut came off & is loose in the tranny housing, so that's what the rattling sound is. The 5th gear may be still on the shaft, so when you lost it, it had slid back on the shaft. I've heard several guys say that after the nut came off, the 5th gear slid back forward to re-engage the tranny. You definately need to take the rear cover off to see what's going on like Rich said. What you don't want to happen is the gear nut to bounce around loose inside & tear other parts up.
yea you can just be careful about stripping the bolts on the tranny only a 12 point socket will work. pull your drive shaft then pull the transfer case.support the tranny and drain it.remove the cross brace for room. about a 2 hr process for a beginer
You definately don't want anything loose in there cause it might get caught up in the gears & make big problems. Its either the 5th gear nut or gear itself that's rattling. Its really not hard to get the rear tranny housing off, most of the labor involves removal/install of transfer case & driveshaft.
VERY common problem...Now the decision as how you want to fix it.....band aids, improved nut. Will last awhile. New main shaft will last a awhile longer.
For the time and $$$ I would look at a G56 ( I am in that camp as that is what I did )
what am I looking at as far as a rebuild?
They also sell all the parts you'll need and rebuild manuals
