not firing right
Old Nov 26, 2008 | 09:58 PM
dadwana's Avatar
Unhappy not firing right
I have a 99 24v and when I accelerate at a higher RPM the engine misses, does anyone know where I should start looking in order to track down the problem.
240k miles 2nd injector pump, replaced at 160,000.
Old Nov 26, 2008 | 10:01 PM
Mountaineer's Avatar
whats your location ? Do you work on your own truck ?
Old Nov 26, 2008 | 10:21 PM
dadwana's Avatar
I,m in Ca. and I only do oil and filter changes, However I did replace clutch once and will have a shop do the next one (the guts are too **** heavy) I also had a shop in the central valley do the pump cause thats where it left me stranded.
Old Nov 27, 2008 | 09:33 AM
Of course I would have to be there to examine it to make a full assessment.
Though one time my truck started doing the same thing and after swapping injectors and Injection pump with still no difference, it ended up being a o-ring on one of the cross-over tubes going into the head. They are cheap and easy to replace if you haven't already. So that would be one place to start.
pw58
13
Mar 9, 2012 09:53 PM
allrdcowboy
Feb 1, 2008 03:28 AM
sammy340
Mar 11, 2006 09:43 PM
Timmay2
Feb 13, 2006 08:51 PM
DeaconWayne
Mar 26, 2003 05:20 PM
